Replacement antenna w/ SAT Radio? - NewBeetle.org Forums
Old 02-13-2011, 03:36 AM
Question Replacement antenna w/ SAT Radio?
I've found posts on how to do replace my Beetle Coupe antenna. I've seen several photos of broken/cracked antenna bases. I've seen several ads for replacement antennas and bases. However, none of these states "satellite" radio compatible. I recently bought an '06 NB Coupe, with the full featured Monsoon radio, AM/FM/CD/CD changer/MP3-iPod/Satellite Radio (mine has XM). The antenna base is broken. While the satellite radio seems to work fine, you have to be right on top of any AM or FM station, and, even then, stations fade in and out, so an antenna replacement is indicated. Is the VW dealer my only option? The internet usually has multiple posts for aftermarket parts, but I don't see this one. Please advise............thanks for taking the time....TPM
Satellite Radio Antenna ghostRder1 Technical Modifications 11 02-16-2012 01:31 AM
Antenna replacement khmer.beetle Parts and Accessories 5 04-25-2010 03:30 PM
Replacement Antennas, Antenna Bases and Base Gaskets BUGSTUFF Car Audio 0 01-26-2010 04:19 PM
Problem with antenna wire on after market radio luvmybug09 Car Audio 4 05-04-2009 11:54 PM
Antenna: Reception, Replacement, & Cost Darth Beetle Questions, Issues, Concerns, or Problems with the New Beetle 15 07-25-2008 02:24 PM
