Car door front speakers don't work - NewBeetle.org Forums
Old 03-12-2011, 08:17 AM
Parks92's Avatar
Car: 2004 Vw beetle 2.0
Question Car door front speakers don't work
No noise comes out of them and I can't figure out of to fix them, they are getting power to them
Old 03-12-2011, 09:03 PM
kellyyysayss's Avatar
Mount Holly, NJ, USA
Car: 2000 Beetle, 1964 Comet Caliente, 1966 Mustang
Try them in the rear speaker connection(s). This will determine if it's a speaker issue or a (supply) problem with your head unit.
Old 03-14-2011, 12:42 AM
that guy.
Hattiesburg, MS, USA
Car: 01 GLS 1.8T
If you have a multimeter you can ohm out the speakers to check to see if they are bad or not without touching the speakers themselves pull the radio and use the multimeter to test the front door speakers. They should ohm out around 3.0 to 3.8 any crazy low or high numbers means that the speakers are just bad. This is a common thing to happen with stock speakers. If the speakers ohm out correctly then its the outputs on the radio itself then you should just replace the radio. If you need to know what color the wires are for the speakers check over at the12volt.com
Old 03-14-2011, 05:35 AM
Parks92's Avatar
Sweet thank you guys
I will try it
Tags
speakers
I just burnt both front door panel speakers.... vfoeller Car Audio 0 07-19-2010 10:35 PM
Speakers won't work after new HU install Osgood Car Audio 0 03-22-2010 03:16 PM
99 new beetle radio front speakers dont work newbeetle923 Questions, Issues, Concerns, or Problems with the New Beetle 3 03-13-2010 08:17 PM
Driver's side front speakers don't work Mello Mike Car Audio 3 08-22-2008 12:59 AM
Please help....both front door speakers went out mooshi Car Audio 1 07-16-2007 01:05 AM
