03 Turbo S with Monsoon tape deck and factory cd changer in the hatch:
I would like to add an amp and small sub to the existing system. Does anyone know which wire on the CD changer harness I could tap for a remote on? It would make it some much faster not to have to pull the deck to tap the remote lead. Thanks all, Jon |
no, I just need the remote on/off. This is usually a blue wire that acts as the signal wire to the internal relay in the amp. Main power will be pulled right from the battery but without a signal to turn it on or off when the radio is on it will never shut off.
Typically this is done by tapping into the radio harness or a switch 12v source at the fuse box. I just figured that there was an existing wire that I could tap into running the factory CD changer. The amp I will be adding will only be used to power the sub and not any of the existing speakers. Thanks, Jon |
I believe I tapped the back of my deck...so not much help here. Where are you tapping for the inputs though? I went off the back of the deck for that as well...when I still had my Monsoon.
Project Sub- 2002 New Beetle This is probably no help, but the wiring diagram can either be found on in the how-to section or on the top of the radio if you end up pulling it. There is a thread that MyOther... started a while back that was all about stock radio and I attached many pdf's one is a wiring diagram of the monsoon system. That might be what you are looking for. I used that diagram to completely remove the monsoon from my car and wire in a new amp for the highs recently. (the monsoon amp wouldn't turn off)
The COMPLETE GUIDE to Factory Audio Systems! I still think the power lead to the changer is switched, and only powers up when the Changer is called upon. M. |
| Will a Monsoon AM/FM Cassette work in a non-Monsoon equipped 2000 Beetle? | pmorg98 | Car Audio | 5 | 05-09-2011 11:21 PM |
| Adding another VW to the family | Hambug | Water-cooled/Current | 0 | 06-20-2010 10:46 PM |
| Wanna Trade? '02 TurboS Monsoon Deck for your non-monsoon? | Plummkrazy | Market Place Archives | 1 | 07-24-2007 12:39 AM |
| FS: 03 NB Monsoon Tape Deck w/ Monsoon Amp | nagal | Market Place Archives | 12 | 08-09-2006 09:39 PM |
| HA! HA! Made Monsoon CD work with NON- MONSOON CAR!!! IM Pure Evil!! | mezonesxbox | Car Audio | 1 | 06-28-2006 10:47 PM |
