audio ups and downs - NewBeetle.org Forums
Old 03-31-2006, 08:27 PM
58ragtop's Avatar
im never drinking again
vancouver, WA, USA
Car: 1999 blue GLS 2.0 5sp
Default audio ups and downs
hey all, i have a 99 gls with an audio or power problem i need help with.
i have all factory gear and have added on two jl audio 8" subs and an amp.
the problem im having is with the volume, it randomly changes,. one minnute it's cranked...the next second it's fading, is this a power problem or a head unit problem?? i dont think it's as simple as putting a capacitor on the power, it's sound more like a power managment isue, im i right???
any help and possible fixes would be great :-)
thanks
jerry
Old 03-31-2006, 08:57 PM
Crazy_MoFo's Avatar
It's a shot glass!
Back Home Again( O.C. SoCal), USA
Car: '98 Cool White 5 Speed 2.0L GL
Does the volume go up and down on all the speakers or just on what ever the amp is hooked too? If it's on all the speaker then it sounds like a head unit problem.
Old 03-31-2006, 09:21 PM
58ragtop's Avatar
vancouver, WA, USA
i geuss i should have added it only does it at high volumes :-)
the sound decreases and then after a while it will increase back up to where i had it originally, it really feels like it's power management isue, but im not sure...in have a second head unit and it does the same thing...just checked it out.
another question though, is the amp in the head unit or seperate in the car some where?? it's just a simple stock tape deck with changer controls..
Old 03-31-2006, 10:18 PM
Steinola's Avatar
Portland, OR, USA
It... uh... wouldn't happen to be occuring as you're changing speed, would it?
Some NB headunits had Automatic Volume Control that is supposed to raise the volume as your vehicle speed increases (it assumes at greater speed, there will be an increase in wind and road noise), and lower the volume as your speed decreases (so it's not still blasting full volume while you're sitting at a stop light).
If your headunit has AVC, you can adjust the main level (and possibly defeat the feature altogether) in the system menu accessed by pressing and holding the scan button for several seconds.
Just a thought. I'm not sure that's what it is, or not... or whether your particular headunit even has AVC. I just didn't want to see you spend a whole lot of time and resources researching this as a "problem", when it may actually be a "feature".
Old 03-31-2006, 10:48 PM
58ragtop's Avatar
vancouver, WA, USA
no it is not a avc system....thought of that allready :-)
i geuss m going to have to put a call into a vw dealership....
VW Audio Interface Adapter neko Car Audio 2 03-27-2006 04:21 PM
audio question from a noob Javier Car Audio 4 02-03-2006 08:41 PM
Audio Ignorant!!! XM Questions AmyJane Car Audio 6 12-15-2005 01:45 PM
Need Audio Advice lebicicletta Car Audio 8 10-31-2005 09:57 PM
Technical Bulletins - Audio marvins_dad Audio/Video How-To 1 10-10-2005 12:57 AM
