hooking up amp/subs to stock deck - NewBeetle.org Forums
Old 04-18-2006, 02:15 AM
New to VW, not to cars
Toronto, Ontario, Canada
Car: 2000 beetle 1.8T
Default hooking up amp/subs to stock deck
Hey, I'm considering installing a pair of 12" subs. I had them in my old car which had an aftermarket deck, but the beetle has a stock tape player in it.
How would I go about installing the amp to the stock deck. I know I would run the power wire from the battery to the amp, but what about the remote wire and RCA plugs?
I haven't looked behind the deck yet, I'm just trying to find out if its worth the effort, and if it is difficult.
Thanks for any info.
Old 04-18-2006, 03:29 AM
58ragtop's Avatar
im never drinking again
vancouver, WA, USA
Car: 1999 blue GLS 2.0 5sp
did this to mine allready :-)
you will need a high to low converter like this one in order to hook up to your factory deck---
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
use your test light to find the red wire on the stereo wire harness that is hot only when the ignition is on...this is your remote wire :-) i simply ran this wire and the power wire under the door sill cover and to the back.
for the high to low converter i took leads from the back spks just cas it was easyer, if you want to run spk wire from the deck, you will have to get a wire code from some one on what wires go to where...
hope that helped :-)
"no matter where you go.....there you are"
buckaroo banzai
Old 04-22-2006, 05:29 AM
Crazy_MoFo's Avatar
It's a shot glass!
Back Home Again( O.C. SoCal), USA
Car: '98 Cool White 5 Speed 2.0L GL
I used this: Blaupunkt Preamp Output Adapter. 8 pin ISO to 4 RCA. Model - F00E500014
it plugs right into the back of the stock stereo, and has a Remote On wire. I don't know if the remote on wire works on the Monsoon deck but I know it works on the Non Monsoon deck.
1-160 mph /Stock brakes (front&rear) tonysailor Market Place Archives 0 02-08-2006 12:58 AM
Monsoon New CD Deck Questions Mr Natural Car Audio 34 02-05-2006 01:03 AM
Hard Start (sometimes) & Rough Ride (~42mph & ~2000rpm) AlisonLS Questions, Issues, Concerns, or Problems with the New Beetle 0 02-03-2006 01:38 AM
audio deck resets to radio Bisonman80 Car Audio 2 01-13-2006 10:23 PM
FS: OEM Monsoon Tape Deck jeff Market Place Archives 4 11-20-2005 09:49 PM
