I bought some RAAMat BXT and tried to install today. Unfortunatelly, it didn't go as planned
![]() I wanted to do both inner and outter door skins, but had trouble removing the inner door skin panel. I undid all screws, but the bloody power window screwed everything up. I had no clue how to get that panel out since the window rail is connect to it. I don't see the point of putting the material only on the inner one since it won't help my need and I'd rather do it once. So, did anybody install something like that in the doors? I know I saw a picture of install on VWVortex somewhere few days ago, but I tried looking for it so I can contact the user but couldn't find it anymore ![]()
2003 VW Turbo S Platinum Grey |
I bought some Spray-on stuff made by CAE for my doors. So i just sprayed over the wiring and stuff (i amsked off the motor of couse). The real thing is that i dind't see any difference in sound quality and/or deadening. I guess the spray was for more to stop rattling then deaden sound.
But anyway, yeah, good luck with taking that panel off, that panel has the window regulator rivited to it, and i'm pretty sure you need to unmount the window before you take it off. and i think there is a screw or 2 at the bottom of the door where the rails are.
You need to remove the window to remove the panel. I have only done it in my Jetta. It was pretty simple.
Remove the trim panel. About half way down there should be some large plastic plugs you can pop out. These are to access the clamping bolts for window. Lower window about half way to access the clamping bolts, loosen the bolts and lift the window up and out of it tracks. I am assuming that the VW engineers didn't do anything to drastically differant than the Jetta. Tom
1999 NB GLS TDI 1999 Jetta GL TDI |
The best thing you can do for your door speakers is to install speaker baffles behind them. Crutchfield has them:
http://www.crutchfield.com/S-1cJ4rWF...vs=T&o=v&g=760 They will protect your speakers, cut road noise way down and tighten-up the bass. Best stereo mod for the money. Be careful that they don't interfere with window operation. juice |
beetlejuice, do you actually have those? I read some comments on Crutchfield and they weren't so good, so I dunno. I did some more reading on them and they were mainly made to protect speakers from water and actually muffle the sound. Take a look at this thread: http://www.diymobileaudio.com/forum/...&highlight=XTC
Thanks TMielke, that helped out a lot! I did both inner and outer skins, but was kind of dissappointed by the affect. Although, one side was better than the other where I applied two layers of RAAMat and Ensolite foam. Looks like I'll have to do the same for other door. |
juice |
| Doors aren't flush | Vayleen | Paint and Body | 5 | 05-02-2006 07:31 PM |
| With Sound On, Please! | PhoenixRising | Miscellaneous Hoo-Ha Archive | 8 | 03-19-2006 04:34 PM |
| DP Sound | 2000GLX | 1.8 Liter Turbo | 3 | 01-21-2006 05:31 AM |
| Berties new sound! | bug008 | New Member Forum | 5 | 01-20-2006 09:17 AM |
| I need two new doors | Tuckervill | Paint and Body | 0 | 09-28-2005 05:48 PM |
