What engines fit into the 99 beetle? - NewBeetle.org Forums
Old 07-12-2006, 05:12 AM
Default What engines fit into the 99 beetle?
I'm looking to pick up a friend's car but it's got a bad engine. I would just like to know what my options are for replacing the engine. Thanks for all the help.
Old 07-12-2006, 05:35 AM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
the easiest swap would be for same engine code and possibly year.
If you go differnt, any 1.8t, 2.0, or tdi will bolt in there with ease but you'll need a differnt ecu and wiring harness. You'll need to run intercooler piping for hte tdi or 1.8 if it's a 2.0, and you can fit a vr6 in there, but you'll need vr6 motor mounts, and tranny, and axles, etc.....
Also, early '99 bugs, lime mine have cable driven trottles. The later models have drive by wire. That should probably be your #1 concern of doing a differnt motor.
will these wheels fit a beetle? bobbittle Styling Modifications 5 06-11-2006 11:45 PM
MY New Beetle 2000 2.0 with Perfect Fit cover mezonesxbox Photos: New Beetles 11 05-30-2006 01:19 AM
Buying a 1.8t Beetle - questions about engines/options sleds4ever 1.8 Liter Turbo 18 03-14-2006 04:19 PM
Will Jetta roof bars fit on a beetle? Jay1 Miscellaneous Hoo-Ha Archive 3 12-10-2005 02:29 AM
Will these fit a new beetle? slugo Questions, Issues, Concerns, or Problems with the New Beetle 2 11-17-2005 04:19 PM
