2.0T for 1.8 T - NewBeetle.org Forums
Old 11-10-2006, 03:26 PM
Transmission Shop owner
Oakland, CA, USA
Car: 2000 1.8T
Default 2.0T for 1.8 T
Has anyone done a 2.0T for a 1.8T? What is involved?
Old 11-02-2007, 12:32 PM
i was just wondering the same thing myself.....
Old 11-02-2007, 12:58 PM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
recently I found out that the VR6 is a direct swap
don't know abt 1.8t tho
Here's a look at Ladybug
Old 11-02-2007, 02:57 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
Wouldn't it be cheaper and easier to go BT on the 1.8T?
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 11-06-2007, 12:13 AM
dmk's Avatar
dmkRegistered Member dmk is offline
I would think so. Isn't the 2.0t running a higher compression ratio as well? Limiting the gains without some additional internal mods (pistons)?
'99 Techno Blue 1.8T New beetle.
APH engine, 5spd
It's not hard to fail,
it's not easy to win!
Old 11-06-2007, 12:55 AM
vdubbugman53's Avatar
Arvada, CO, USA
2.0t is a much better engine to tune...i would not swap it if i already had a 1.8t but if i was going to swap a 2.0 for a turbo engine i would pick the 2.0t over the 1.8t anyday
Old 02-26-2008, 10:59 AM
Anaconda's Avatar
formerly known as BROWN E
Austin, TX, USA
Car: 2001 NB 1.8t
Has anyone even done the swap yet? My 1.8t is utter crap due to it being a used motor and am looking for options atm on what to do with the car.
http://www.myspace.com/4603066
Old 02-26-2008, 04:04 PM
Arvada, CO, USA
if you already have a 1.8 why not just put another 1.8 in it. it is a direct and very easy swap. just find the same year engine code then swap it and plug it in.
Old 06-07-2008, 09:52 AM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
I went in the middle and bored mine to a 1.9t, could go up to a 2.1t if I got a stroker kit.
MySpace -- Piczo Pics -- WoW
HVWC 2010 Public Relations
Old 08-05-2008, 09:23 PM
TDI_ME's Avatar
Have Vag-Com, You Travel
Jonesborough, TN, USA
Car: 2001 Beetle GL TDI, 2005 B5.5 Passat TDI, 2006 Jetta 2.0T FS!
It is exactly the piston design and FSI that allow for massive power gains in this engine. The two combined allow for a cooling effect allowing the engine to run much higher compression.
Old 08-10-2008, 08:10 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
I haven't seen any 2.0T swaps into older chassis (yet), not sure of the specifics on it though. I'm sure you'd be looking at transmission, wiring harness, fuel system (if any upgrades needed, the Mk5s do run a fuel filter with an internal pressure regulator), intercooler (as they are front-mount, would probably need an upgraded sidemount for this application)...
Figure it'd run a few bucks to do it, not sure of the return on "investment" but the 2.0T FSI is a peach of an engine, I will attest that from personal experience.
Previously:
Old 08-11-2008, 11:07 AM
Picknicker's Avatar
Germany
Car: '99 2.0i
Depending on the motivation:
A 1.4TSI (the one from a Golf MK5 GT) would be equal on HP and torgue but much better on milage.
The 2.0 TFSI would be more powerful but not better on milage.
Old 08-12-2008, 02:04 PM
FallinApartBoy's Avatar
I Want A 2.5T
Dayton, OH, USA
and there is no good way to bi-turbo anything with single manifolds. you end up wasting boost produced by one of the turbos and you get better response from just doing one giant turbo. and i agree to just keep the 1.8t and put some money into it. like they said you could bore it out to a 2.0 and add a bigger turbo, front mount, and chip it and be looking at way more hp and torque than the 2.0t with a lot less money im sure.
Old 08-17-2009, 03:58 PM
pyro's Avatar
United Kingdom
yep ive done one.
2.0 now Audi S3 1.8T
Old 02-10-2010, 10:42 PM
Kevmar83
Denton, TX, USA
Car: 64 Corvair, 02 WRX, 90 Corrado, 01 RS, 66 Corvair Convertible, 85 jetta
Default 2.0l FSI bottom end with 1.8t 20v head
Is this a 2.0 FSI short block with a 20v 1.8t head? I am building a engine for my 85 jetta and I have a 2.0l FSI engine and a 1.8t engine. So I was thinking 2.0t 20v I've got the 1.8t at the machine shop now and I'm about to start tearing the FSI engine down. any thoughts or has anyone seen this done before
