I know its been gone over before... VR6 swap.. - NewBeetle.org Forums
Old 11-19-2006, 12:48 AM
Holland's Avatar
Beetle Is Bad As Can
Arcadia, CA, USA
Car: 2000 1.8T Beetle
Default I know its been gone over before... VR6 swap..
I have a 2000 1.8T and I also have a 2000 VR6 with a O2M 6 speed. The motor has 100k on it and im starting to pull it apart to do big pistons and rods. Im going to do a turbo VR6!!!! Im using a Mega Squrt EFI system... I'm going to shoot for 450-550HP.. ok here is my queston... cooling.. what rad and fans do you use.. i know most of the stuff is kinda easy but thats my only queston for now as I start to get more parts..ohh and has anyone done this with a aftermarket EFI systm... I want to keep most of the dash stuff working..ie spedo and tach.. PM if you have done this... Thanks... I hope to have some mock up picks up in a few weeks
2000 Reflex Yellow 1.8T GLX Mods, O2M 6 speed, EFI systrms DFI, GT30 Turbo, MBC, 62ibs Injectors, 3in Downpipe and Exhaust,custom water/air ic, ATP Exhaust Manfold, ATP Fuel Pump,Adjustable FP Reg, AutoTech steel flywheel W/Power Clutch, and HKs BOV, stroked to 2.0L, ported head W/shrick cams. 11,70@122..Dyno 409HP 370TQ @ 12PSI on 116 Octane. Other cars, 07 Tahoe LTZ and 06 620HP LS2 427ci GTO..FTI cam,AFR Heads,FAST Intake,Kooks Headers, and 175 NX Nitrous..9.73@142 on nitrous..
Old 06-30-2007, 01:01 PM
loganskinner's Avatar
Lakeland, FL, USA
Car: 2000 Arrow Silver GLS 1.8T
THE BAD
unless you plan on an AWD system or just a car to do burnout contests with, 550hp is way too much. a couple years back, a few of the guys who work at the local volkswagen dealer did exatly what youre talking about, turbo vr6/450hp, and although it really was badass, they found out the hard way that it was a mistake. they had a battle with traction that they couldnt win. i mean, the car wasnt really even streetable because of it. they tried all sorts of setups and couldnt get anything to work as well as they wanted it to. needless to say they ended up selling that motor and did up a 1.8T to 330hp and it worked great. the car really flew.
NOW for the good stuff. dont get me wrong, its a great idea and im not trying to defer you from it. im sure with the right knowledge and time you can get it set up right. hell, maybe the volkswagen guys didnt know what they were doing. who knows. if you really want to do the project, i can get with them and see if they have any advice for you before you begin.
Double-O Turbooooo.
Float like a butterfly, sting like a HOWITZER
Lakeland, FL, USA
THE BAD
VR6 Swap Labour SMG Engine Swaps 14 04-14-2008 09:03 AM
VR6 Swap VR6Bug Engine Swaps 9 10-16-2007 11:09 PM
Swap Euro V5 Engine for VR6? mattsimis Engine Swaps 11 05-23-2006 05:24 PM
Beetle VR6 Swap questions Ghostrider Engine Swaps 4 05-13-2006 08:29 AM
Vr6 swap, mechanics? SinfulDeity Engine Swaps 4 12-16-2005 08:46 AM
