Need new head for '99 Turbo - NewBeetle.org Forums
Old 03-02-2007, 03:20 AM
Casperturbo's Avatar
Casper, WY,
Car: '03 GLX
Default Need new head for '99 Turbo
The timing belt slipped and my valves are toast. Can I buy and install a head from an Audi 1.8t? I can find several of those online. I believe mine has 20v, are they interchangeable?
Old 03-02-2007, 01:39 PM
OH, USA
Car: 03 GTI
I believe some would be. In the NB at least, in '01 there would be a few and '99 and '00 should work, but most '01 would be a later engine design that had variable valve timing--I don't know when it started in other vehicles. So if you can figure out how to identify that (I don't know) you could be on your way.
Old 03-02-2007, 02:01 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Do you know your head is toast? Mine was repaired 6 months ago and seems to do well under pressure (lead foot disease). Mine went at about 60mph. Only had to replace 4 valves. A shop is MUCH cheaper than a stealer. You should look into it. Good luck.
Old 03-02-2007, 05:16 PM
bugfreak's Avatar
DFW, TX, USA
Car: 2 turbos- Pookie (custom blue) and Mookie (yellow)
i got a rebuilt head at a good price. if you're in the dallas/ft.worth area, i know a couple places. if not, you might try your local yellow pages or something.
Old 03-04-2007, 12:15 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
YES! you can!
get a 96-98 head if you can, they flow the best. easy upgrade right there, will give you more power if you modify.
Old 03-04-2007, 02:14 PM
Casper, WY,
Car: '03 GLX
Thanks for all the replies. I don't know how many valves are bent but suspect it is quite a few. It died going down hill and I popped the clutch a couple of times trying to get it going again. My mechanic is not the fastest guy in the world but he's good and honest. I wouldn't take this to the dealer here for anything, he's the loser of losers. This is a small city and it'd be tough to locate something local, I think. Would this one work for me?
http://cgi.ebay.com/ebaymotors/Audi-...spagenameZWDVW
Old 03-04-2007, 02:43 PM
The Cheat's Avatar
that's the head you want!
aeb heads flow the best.
Old 03-04-2007, 06:04 PM
Casper, WY,
Car: '03 GLX
He tells me my engine is APH. Are you reasonably sure this will work without any modification?
Old 03-04-2007, 07:14 PM
gilligan's Avatar
MI, USA
All I know is that if justin says it will work then it will work, he's a vw dictionary of knowledge.
Old 03-05-2007, 01:44 AM
The Cheat's Avatar
oh it will.
when i build customer motors (unless it's a tt225), i always use the aeb head as it's the best flowing head...means you get more air going through...means more powah!
i've been doing this too long to not know that it'll work.
Old 03-05-2007, 04:58 AM
Casper, WY,
Car: '03 GLX
Missed the one on eBay, is $500 a good price? Anyone got one that they want to sell?
Old 03-05-2007, 05:50 AM
The Cheat's Avatar
500's not a bad price at all.
vortex members use these heads on the 2.0 block to make some sick power combos...i still haven't figured out how that works, but hey, i guess it does.
the trick is to find one as clean as possible with as low miles as possible.
Old 03-05-2007, 02:37 PM
Casper, WY,
Car: '03 GLX
What does it normally cost to have one rebuilt? I'm assuming that the valves need to be replaced on mine, is that an expensive proposition? Is there more to it than that? Is my old core worth something?
Old 03-08-2007, 02:49 AM
Casper, WY,
Car: '03 GLX
Looking for a head for a 1.8 turbo 20v. Prefer complete. AEB, ATW or others.
New CD head unit? TODDREY New Beetle Convertible 1 07-31-2006 12:48 PM
Turbo S Head Unit SIX SPEED Market Place Archives 1 07-01-2006 01:12 PM
Probably Need Cylinder Head kjeichen 2.0 Liter Gas 2 06-21-2006 04:56 PM
Monsoon Turbo S Head Unit F/S eBay BitBoy Market Place Archives 4 04-19-2006 01:11 AM
VOLKSWAGEN TURBO BEETLE Head light Headlamp hdtv 1.8 Liter Turbo 6 02-21-2006 06:51 AM
