2000 VW Beetle 2.0 - NewBeetle.org Forums
Old 12-09-2007, 03:13 AM
Default 2000 VW Beetle 2.0
Ok, so here's the deal, I have a 2000 VW beetle with a fried engine. So I have been trying to do some research and figure out what the best thing to do would be.
Im looking at replacing the engine with another 2.0, so this is where things get sticky. I can pick up a 2.0 out of a 96 golf for $300, but i read somewhere about conflicts with "drive by wire" vs a throttle cable. Does anyone care to elaborate for me please? The second conflict I find is on a few ebay pages, so im looking for a 2.0L engine and there seems to be some distinguishing factor between a 2000 2.0L and 2001 2.0L. What are the differences?? My logic would lead me to believe that none of this should matter as long as the actual long block is the same, and i can just use all the other parts from the engine im pulling. Like the intake manifold and what not.
And if someone could point me to a swap write up that would be kick ass too. Thx and sorry for the long post.
oh and I would consider myself a semi-experienced mechanic. Ive swapped engines in Honda's before but never a V-Dub, this seems to be a completely different beast.
Old 12-09-2007, 05:02 AM
From what I understand VW motors are backwards compatible. Meaning that a MK4 motor will have all the mounts for a MK3, MK2 and a MK1.
But the 96 would be a MK3 and the Beetle is a MK4 (based on the MK4 Golf platform).
Try looking a bit harder, you'll find a MK4 2.0 for cheap without looking too hard.
Old 03-08-2008, 03:31 PM
Hey - I'm just finishing up with a similar project. Pulled old engine out and put in a new longblock. The 96 you are talking about has the 'ABA' motor. Your Beetle has the 'AEG' motor.
I think the main difference is that the ABA has a standard type distributor and rotor, while the 2000 has an electronic coil pack. I don't think you can just pull the distributor and bolt on the coil pack because the block and/or mounting brackets are different. It would be a cobble job to make it work.
Also, I don't think the intake manifold will swap from the AEG to the ABA's head, so more problems there trying to get your MAF and and sensors to work..
Long story long... you need to find an AEG motor (98 and newer? up to 200x?) then you can use everything off of your existing motor
Old 04-18-2012, 04:37 PM
Sorry to revive a dead thread, but after looking at this I am curious if I was to change my 2000 2.0l auto for a mk4 2.0l engine with a manual box. Would it fit straight in or would you for see lot of issues with this swap.
If possible which engine would be best? Would it have to be from a golf or would any fit? Maybe even a TDI?
Old 04-18-2012, 05:29 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
If all you want to do is go from Automatic to Manual; just swap the transmission.
My NB Family...
Old 04-18-2012, 05:30 PM
Richmond, VA, USA
Car: 1999 Silver New Beetle GLX 1.8T 5 speed ,2007 New Beetle 2.5L 5 speed Harvest Moon
Any engine from any of the mk4 platform will fit for the most part. You will have to modify almost anything you put in unless it's the same generation 2.0L. The 1.8T wouldn't be too difficult to swap in or even the newer 2.5L from possibly a wrecked donor car (2006+up). The most difficult route would be the TDI swap. You would have to change fuel system components and much more which could get costly fast. I don't think the 2.0L 5 speed swap would be too difficult. In fact I would say thats the best way to go but you will need to make several other changes when going from auto to manual.
99 New Beetle GLX 1.8T 5 speed silver w/black leather, moonroof, Pioneer head unit/front speakers, and sub, snowbox deleted
07 New Beetle 2.5L 5 speed harvest moon w/ tan leatherette, moonroof, monsoon CD/MP3 w/CD changer(donated by my 99), Hugs& BugsBear(http://www.thecmfoundation.org/)
FS: 2000 1.8T Beetle e46jb Market Place Archives 1 07-24-2007 03:16 PM
2000 New Beetle Genesis New Member Forum 6 10-22-2006 03:34 AM
2000 Beetle Buglover Market Place Archives 1 07-04-2006 09:51 PM
2000 Beetle overheating??????? HELP stevebug Questions, Issues, Concerns, or Problems with the New Beetle 12 01-16-2006 09:30 PM
what turbo is in the 2000 new beetle GENETIX RACING 1.8 Liter Turbo 4 11-29-2005 05:47 PM
