pulling engine & tranny together - NewBeetle.org Forums
Old 02-29-2008, 11:26 AM
harrisville, WV, USA
Car: 2002 gl
Default pulling engine & tranny together
is it possible to do? it's an automatic. can they both drop out of there together as one? I'm wanting to change out them for another.
Old 02-29-2008, 01:36 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
It should be possible, but if you drop it from underneath, i think you might need to remove the subframe to get the engine out. If I were to remove both at once, i'd take off the front bumper and radiator supports and everything then it should just unbolt and then the whole assembly can pull out forward. That's how it works in theory, and how it's done on every other water cooled vw, but i've never actually seen a beetle undressed that way. It is alot to remove to get the engine out, but you are getting unbeleiveable awesome access to everything that is otherwise unbeleiveably hard to get to.
Old 03-03-2008, 01:59 AM
I've been buggered.
Timbuktu, NH, USA
x2... I bet that's the only way to pull a bug driveline, take off the front clip and rad support, swing it out, and lift the engine to clear the lower subframe support/mounts.
Help With Codes: That &*$%# check engine light!!! ptravnic 1.8 Liter Turbo 1 07-11-2007 12:50 AM
Engine & suspension pictures Noviisi 2.0 Liter Gas 2 06-24-2007 08:47 AM
Engine light & Missing!?!? glx2000 1.8 Liter Turbo 2 04-23-2007 10:24 PM
drain & fill tranny ? capacity? your_mom 1.8 Liter Turbo 8 02-21-2007 02:43 AM
Pulling to the Right? Sniper 1.8 Liter Turbo 8 12-14-2006 02:53 AM
