wolfsbürgwe.:Rks Quote:
You should put either one you can find. The power and mas mileage always go in the same direction. The high performance car never advertise the best gas mileage.
It's not a car, it's Volkswagen. Driver wanted. |
sorry bro to much questionz for u but its hard to choose cuxx lots of money to invest and also it is thailand and i think am the first one in thailand who will change this kind of thing on beetle so have to decide clearly okay and actually i dont know much about this two engine so i have to get lots of details on other okay and soory again if u were me u will do like me man thank for ur commnent
Find a complete car that has been wrecked and buy the whole lot. You will get more power from a VR6 straight away.
But if you have the $ for a W12 motor, why not AWD too! ![]() |
stock-for-stock power will be about equal but the VR6 is heavier.
vr6 sounds a lot better 1.8t with a chip will be faster than the VR6 |
a 1.8t will equal a 2.8 or 2.9 vr6 - but even a chipped 1.8t will have serious problems with a 3.2 or 3.6 vr6 i guess...
a 3.2 has (stock) 241 HP or 250 HP (depending on the year built) and a 3.6 has 300 HP... Event the torque is higher - the 3.2l engines develop 300 to 320 Nm (221 - 236 lbs ft) and the 3.6l engine develops 350 Nm (258 lbs ft)... A 1.8t will be faster from 50mph to 80mph in the last gear (more torque in the lower rpms 'cause of the turbo)... |
i've seen 1.8ts with bolts ons do 210-220ish whp and 260ish wtq...
the VR6 is also quite a bit heavier (power/weight) and will most likely throw off the handling of the car.. plus, you should probably change out the front suspension if you're adding a VR6, which i just going to add to the cost.. but if $ is no object, 2.8T is pretty fun. |
600whp - that's evil!The weight problem might be an aspect. Though - I don't know how much weight the whole turbo thing (charger, intercooler) adds for that the vr6 is no real V6 - more a row 6 with the size of an row 5 or large row 4... But I really dunno... A scale and two engines would be nice Anyone swapping a 1.8t with a vr6 ? |
