Hey.. yes another VR6 swap questions.
The problem is that there is too much information and too many opinions that are posted. Can some one give me advise on what I should do in my case. My wife has blown our 1998 VW Beetle 2.0 auto. It only had 46,568 miles on it. I purchased a 2003 VR6 GTI 24v Motor with a 6 speed Tranny. I have bought the complete engine, tranny, wiring harness, ecu, hoses, shift assembly, pedal assembly, Clutch cable and anything that looked important off of the fire wall and fenders. Questions... Will it fit? Did I get all parts that I need? Do I need the cluster? Do I need the Ignition Module and Keys? I have it on the cradle... will it bolt right up? What kind of Exhaust Modifications will I need? What type of wiring issues am I going to have? I also have a new universal turbo system, should I install it now? Here are the specs.. - T3/T4 63 Trim, A/R 50 V-Band Turbo Charger w/Internal Wastegate(8 PSI) - Manual Boost Controller - FMIC (Intercooler) Core Size 21"x6"x2.5" w/ 2.5" Inlet & Outlet - 2.5" FMIC Alumminum Piping w/ Silicon Hoses and Clamps - Complete Oil Return Kit - GReddy Type-RS BOV - 2.5" Aluminum BOV Adapter Pipe Thank you all for your comment and advise... Most of the links are not working anymore... and Pictures of previous installs would be great... jmpellegrino@comcast.net |
Honestly, you will probably have better luck with your questions on the Vortex.
from what i've heard and seen, a 24v vr6 is already a really tight fit in a beetle engine bay. the fact that you have a turbo one means your gonna need extra space. i wish you luck. i would love to see it.
You will need the cluster and ignition key. You can make the beetle cluster work with it but you need to know how to do by VAG com. You will need the exhaust system for VR6. If the donor car is GTI so it would fit New beetle hanger. Like VR6 said above that leave the turbo behind for a while. You will need to know how the engine runs and the room to set up the turbo. Also, don't forget the suspension. The lower springs or stock springs for beetle only work well with 4cycles or 1.8T not VR6. The Engine and transmission mounts are important. If you want plan for turbo in the future, get the VF engineering mounts for VR6. If not, stay with VR6 stock engine mounts which are strong enough.
The turbo set up is another story that you will have to design how you want your car looks, stock or agressive looking. HPA water intercooler set up is a good choice but you have to remove the battery. The front intercooler take the air directly but front bumper has to be cut or you have to get aftermarket or Turbo S bumper to get more air. I'm doing the swap soon and also plan to set up turbo in the future. I use the lupo cluster which are similar to RSI and R32 motor with GLI 6 speeds tranny. My car is converted from automatic too. ![]()
It's not a car, it's Volkswagen. Driver wanted. |
I don't know if you ask him or me
, but I got the wrecked R32s from insurance company auction (my friend auctioned for me). |
Wow,
Thanks guys, for stepping here. I pleased to say that I actually have things covered, from what it sounds like. However the motor mount thing... I just figure out. My motor is sitting crooked. I posted pick below. There was an add in Craigslist that had a part out from a 03 GTI with 23k miles that was rolled. The only damage that the Motor suffered was a cracked Intake manifold. I replaced that. I made sure to vacuum out the Intake ports. Wow am I glad I did that. Chunks of the plastic manifold came up. AS FAR AS BEING A TIGHT FIT... oh yes it is! But there is actually a lot of room from the exhaust manifold down. You at leas have a 1ft deep x 2ft wide x by 2 feet down back there. There is enough room for a Twin Turbo set up. Here i8s the list of the parts I took. Motor and tranny Down pipe with converter and 02 sensors ECM and Wiring Harness Interior Harness Cluster, Ignition Module and Key Peddle Assembly, Clutch assembly Clutch Hydrolic Hose and shifter assembly Everything above was $4,000. Not including the other things needed. I will wait on the turbo stuff for now. I need to purchase the Half shafts and MAF. I plan on relocating the Battery to the rear. I really need to budget stuff now. I will be purchasing 4 RSI kits from UK within the month. Anyways, I am stuck at the moment with the wiring. I'm not sure if I completely take out thold one, cause has the ABS, Headlights and other interior stuff. Should I leave the old harness powered up but only remove the the engine parts. Because my car was an automatic, how do I hook up the Clutch switch... things like that are the stuff i am facing now. Beside the motor being crooked. Enjoy the up to date pics... ![]() ![]() ![]() ![]() NOW FOR THE SHOT OF WHERE YOU CAN SEE IT IS CROOKED... ![]() ![]() ![]() Last edited by JMPELLEGRINO; 09-24-2008 at 06:27 PM.. |
Wow,
Thanks guys, for stepping here. I pleased to say that I actually have things covered, from what it sounds like. However the motor mount thing... I just figure out. My motor is sitting crooked. I posted pick below. There was an add in Craigslist that had a part out from a 03 GTI with 23k miles that was rolled. The only damage that the Motor suffered was a cracked Intake manifold. I replaced that. I made sure to vacuum out the Intake ports. Wow am I glad I did that. Chunks of the plastic manifold came up. Here i8s the list of the parts I took. Motor and tranny Down pipe with converter and 02 sensors ECM and Wiring Harness Interior Harness Cluster, Ignition Module and Key Peddle Assembly, Clutch assembly Clutch Hydrolic Hose and shifter assembly I need to purchase the Half shafts and MAF. I plan on relocating the Battery to the rear. Anyways, I am stuck at the moment with the wiring. I'm not sure if I completely take out thold one, cause has the ABS, Headlights and other interior stuff. Should I leave the old harness powered up but only remove the the engine parts. Because my car was an automatic, how do I hook up the Clutch switch... things like that are the stuff i am facing now. Beside the motor being crooked. Enjoy the up to date pics... ![]() ![]() ![]() ![]() NOW FOR THE SHOT OF WHERE YOU CAN SEE IT IS CROOKED... ![]() ![]() ![]() |
I got the Motor mount on the passenger side.... it is different... i'll post pics.
okay... My beetle was an automatic. So I purchased the Interior harness as well so I can get the switches for all of the clutch stuff. Anyways, so I am not sure if I should yank out the interior harness of the beetle or just leave it hooked up, with power for all the other stuff. Or is just adding the clutch switch and wiring enough. Since I have the GTI Cluster, I was going to use both the motor harness and the interior harness .... WELL ****! I don't know what to do! I'll get my head straight take pics and post my thoughts... |
I talked to my buddy yesterday about your concern. He said the 98 beetle will have the totally different wires from later models. You may have to use all wiring from GTI since the battery connecting pins are different. I can't remember how many pins of each have.
What style of A/C came with the donor car? If it was 3 knobs like beetle. You should be fine. The airbag sensor plugs are different but you can just spice and connect to the original wire of airbag plug on the beetle.
I will be doing this swap in the next few months. This thread is full of good start of project info.
Subscribed
www.timmurraycomedy.com http://www.facebook.com/people/Tim-M...00001646799397 Friend me
| now i got my NB, need info for mod. | Seanele | Technical Modifications | 3 | 12-20-2007 05:01 PM |
| 401(k)s Wanting to know info! | crazi_daisy | Miscellaneous Hoo-Ha Archive | 7 | 06-10-2007 02:43 PM |
| Anyone done a 02M 6 speed Turbo S swap? I am having some problems.. | Holland | Technical Modifications | 1 | 04-08-2007 09:14 PM |
| 6 speed transmission swap?! | jezter | Transmission Talk | 0 | 02-19-2007 01:59 AM |
| Need a little info | Blue_Stinkbug | Miscellaneous Hoo-Ha Archive | 2 | 12-30-2005 05:49 PM |
