Hi Group,
We are planning to replace the 1.8t engine in our 2001 new beetle.Will car need to be raised on hoist(s)? Any advice before we start? We are hoping to rebuild it and/or replace it? Any Ideas? Any Comments? Any helpful suggestions? We are looking for easy and simple rather than exotic or complicated? Thanks for now, kevin |
Basically, you have the following:
Engine: Remove the cowl (extension into the engine compartment) to gain some room. electrical - handful of sensors / solenoids (just label everything as you go). Plumbing - a bunch of radiator hoses, nothing special Air - Remove everything from the air box to the turbo, from the turbo over towards the intercooler and from the outlet of the intercooler over to the intake. The connections at the turbo are a little hard to get to. Exhaust - pull the 3 nuts holding the downpipe to the turbo. Fuel - remove the 2 lines from the filter to the IP. ** I'm going by memory so there is probably a couple other things ** Transmission: Remove the axles ,the shift linkage and wiring to any sensors. An auto should also have tranny cooler lines going to the radiator. At that point, you should be able to support the engine, remove the motor/tranny mounts and drop it out. I highly recommend getting the Bentley manual. It has detailed instructions showing how to do all this. |
| 2001 New Beetle engine codes? | petah | 2.0 Liter Gas | 2 | 05-24-2008 02:54 PM |
| 2001 New Beetle Hub Cap | stmiranda | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 03-14-2007 12:24 AM |
| 2001 Beetle VR6 | BeetleVR6 | Photos: New Beetles | 20 | 09-25-2006 01:33 AM |
| 2001 Beetle TDI GLS | AnthonyLyndaker | Market Place Archives | 6 | 11-16-2005 07:26 PM |
| engine ping in my 2001 | callisto9 | 2.0 Liter Gas | 7 | 10-06-2005 10:36 AM |
