98 vr6 swap questions - NewBeetle.org Forums
Old 01-10-2010, 09:43 PM
ocala, FL, USA
Car: 05 LB gli, 92 vr rado, 98 bug (soon to be VR)
Default 98 vr6 swap questions
i just got a 98 bug last night with a blown 2.0 im wondering what all needs to be done to swap a vr in it. can i just use the stuff from a mk3 VR? also since its a 98 what do i do for a cluster? and what about wiring? any good sites you can show me that will help with the swap?
Old 01-10-2010, 11:48 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
hmmm, this is where i chime in.
find a 1998 vr6 jetta with lots of rot.
yank the motors out.
install the new motors.
change a couple wires.
profit.
srsly, it's that simple.
Old 01-11-2010, 02:18 AM
ocala, FL, USA
well i found a whole mk4 auto jetta that i can get on the low. what else would i need? i also have a vr bell housing that i heard i can use on the 2.0 trany to bolt it all up.
Old 01-11-2010, 02:25 AM
The Cheat's Avatar
well, i would say to make it easiest, to use a 98 jetta. i've done enough of these, and i can say that if you use mk3 stuff on the 98-99 beetle, it makes it 100x easier in the long run (no immobilizers).
i've never heard of swapping bellhousings, only full cases...
Old 01-11-2010, 02:29 AM
ocala, FL, USA
would any mk3 vr work?
Old 01-11-2010, 02:34 AM
The Cheat's Avatar
any 96-99 mk3 vr will work. get the whole drivetrain, reuse your old axles.
96-99 transmissions are a direct bolt-up to the linkage as well, hence no need for another transmission, just swap speed sensor with the 2.0 unit.
also, once the car gets running, you'll need to code the cluster for 6cyl operation, anyone with a vagcom and 5 minutes can do it.
other than that, well, it's pretty straightforward, takes a weekend.
edit: if i was closer, i'd do it/help ya.
Old 01-11-2010, 02:38 AM
ocala, FL, USA
awsome. it sounds purty straight foward. i have done some other swap. just kinda wanted to know what all was needed before i just dove into it. but thanks for the info. there didnt seem to be whole lot of info about it. but if its as easy as you say then i see why
Old 01-11-2010, 02:52 AM
The Cheat's Avatar
it's soooo easy mate. i did one in 7 hours once, but that was humming along juiced up on the dew and subway steak, egg and cheese.
Old 01-11-2010, 02:55 AM
ocala, FL, USA
well i got a purty good team. im sure we can get it banged out over the weekend.
Old 01-11-2010, 03:40 AM
OH, USA
Car: 03 GTI
Dang Cheat, you make it sound sooooooo e.z.
I'm almost tempted to try it myself on my day off next Friday!
Then on Saturday I could drop on a BT and run some 10's on Sunday!
Old 01-11-2010, 04:09 AM
The Cheat's Avatar
it is easy--on a 98 or 99. as for you bill, like the saying says...don't build what you can buy.
Old 01-11-2010, 04:26 AM
OH, USA
Car: 03 GTI
it is a fave saying of mine, but where can you buy a vr bt nb?
Old 01-11-2010, 04:46 AM
The Cheat's Avatar
tis true.
Old 01-11-2010, 01:19 PM
ocala, FL, USA
well im searching for a mk3 vr6 parts car in fl if any one knows of 1
Old 01-12-2010, 01:16 AM
ocala, FL, USA
would a passat work? i found a whole passat for purty cheap.
Old 01-13-2010, 02:56 PM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
Sorry for the mini thread jack,but in the process of a vr6 swap,are wires spliced & cut up,or is it a clean operation without damaging the oem harness?
Old 01-13-2010, 07:45 PM
The Cheat's Avatar
it can be done cleanly if you know how to move the pins around, otherwise, some splicing is involved.
Old 01-14-2010, 12:59 AM
ocala, FL, USA
can you tell me what pins need to be swaped where? im not to into just choping up a good harness. or if you can tell me what needs to be changed i can get the wiring diag from my work.
Old 01-15-2010, 08:52 PM
98 swap's Avatar
Spokane, WA, USA
Car: 1998 beetle
If you can get diag from woek will you post them because I am at that same spot. Only need a couple more then I am done
Old 01-15-2010, 10:30 PM
raymondlee's Avatar
Seeuro.com
Albany, GA, USA
Car: 98 jetta,87 jetta
what would one do about motor mount positions?
99 2.0 gas swap for ??? huck731 Engine Swaps 13 10-21-2009 01:45 PM
I know its been gone over before... VR6 swap.. Holland Engine Swaps 2 06-30-2007 01:01 PM
TDi swap? Steinola Engine Swaps 37 05-18-2007 02:15 PM
1.8t swap ????'s gtpon22s 1.8 Liter Turbo 0 02-28-2007 11:08 PM
Beetle VR6 Swap questions Ghostrider Engine Swaps 4 05-13-2006 08:29 AM
