2.0 bottom half rods question - NewBeetle.org Forums
Old 06-23-2010, 08:34 PM
Default 2.0 bottom half rods question
How much hp will the stock VW AGG bottom half will withstand?
can the rods hold up against 400whp?
Whats is the limit for stock internals?
Old 06-24-2010, 11:00 AM
RRIDER450's Avatar
Marienville, PA, USA
Car: 1998 VW beetle with mk3 supercharged 12v VR6. 5 speed tranny
not sure on the specs but if i were building the engine to run a 400whp i would be changing the rods. not sure if it would be necessary but if im gonna do it im gonna do it right so i dont have to go back and redo it. i take it your planning on a turbo to get that kind of power? im pretty sure u can get a JE or wiseco Piston kit with eagle rods for around $1000. im planning on makeing 300-350 hp with my N/A VR6 and i know that im gonna be running eagle rods.
Old 06-24-2010, 12:06 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
I don't know what the limit is, but 400 is certainly way out of any range I would call "safe." In the case of a TDI engine, the safe range is generally about twice the stock 90 HP and 152 ft-lbs. Anything more than that and you need to start thinking about upgrading internals.
2000 New Beetle GLS TDI
Old 06-24-2010, 05:33 PM
wee have 4agze here in Jamaica with 400+ whp on stock internals
i was told that Vw engines are forged
IS THIS A FACT?
Tie Rods & Bushings dermusikman 2.0 Liter Gas 19 08-01-2010 08:22 PM
Welded tie rods! ): 70autostick 2.0 Liter Gas 13 01-10-2010 06:13 AM
Head lights and inner tir rods maximus_d Questions, Issues, Concerns, or Problems with the New Beetle 8 08-22-2008 04:54 PM
Deva Dubs 'n' Rods VW Show Blugg TV Blugg Miscellaneous Hoo-Ha 1 06-10-2008 08:15 AM
FS : set of 4 stock AWV connecting rods NBTurboFreak Market Place Archives 1 07-04-2007 08:11 AM
