K & N air filter question... - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > Archive > Miscellaneous Hoo-Ha Archive
Miscellaneous Hoo-Ha Archive Archived Threads from Miscellaneous Hoo-Haa
Old 09-01-2006, 07:12 PM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool K & N air filter question...
In our market, Kragen is having a deal where if you buy a K & N air filter then you will receive a K & N oil filter for free. Not a bad deal on the surface. The cost for the air filter for my '99 2.0 is $60 (which seems a little tall to me).
My questions are:
Will I realize any noticeable difference in the performance of my stock 2.0 or should I just keep the Jacksons in my wallet?...
Does anyone run the K & N air filter in their own stock 2.0?
Are these filters primarily beneficial to those with turbos?
Thank you up front for your comments...
Old 09-01-2006, 07:17 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
K&N air filter will make definitely help ur car breath better, but, IIRC, the OEM oil filter is actually better than the K&N.
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 09-01-2006, 07:18 PM
Billsbug's Avatar
USA
Here's the air filter for about $45 shipped: http://cgi.ebay.com/ebaymotors/K-N-A...23232702QQrdZ1
Old 09-01-2006, 07:21 PM
Toad's Avatar
Hasa Diga Eebowai
Mableton, GA, USA
the k&n filter along with a snowbox removal helps a little. if you also do some plug wires like magnacor's that will also help boost trottle response and let the car run smoother.
But yeah, $60 for a k&n is kinda high.
Come on try a little. Nothing is forever. There's got to be something better than in the middle...
Old 09-02-2006, 01:39 AM
JuggBug's Avatar
CC + JB = TRUE LOVE
PIEHOLE, USA
Car: World Famous JuggBug ~ 2006 Harvest Moon
One of the first things I did on JuggBug was change mine out. I noticed a difference too. I actually needed it because of all the damn dirt and dust around here....stupid desert
TOTALLY SPOILED. BUT TOTALLY WORTH IT.
Old 09-02-2006, 11:46 PM
Maggadog's Avatar
A Touch of Gray
Foresthill, CA, USA
Car: 2006 Convertible
I put a K&N in one of my trucks a few years back. I noticed a tiny bit of power increase, that may have been in my mind and not in reality.
My primary reason for the replacement was economic. The filter and recharge/cleaning kit were quite a bit cheaper in the short run than replacing the regular air filter on a regular basis. If I remember correctly, the payoff point was about 2 years.
Old 09-02-2006, 11:48 PM
oneighturbo's Avatar
Decatur, GA, USA
Car: 2000 1.8T GLX
stick with OEM on both!
oneighturbo.com | flickr | XBL: oneighturbo | beaman
GIAC | O.Z | TOYO | KONI | EIBACH | GHL | VF ENGINEERING | O-Bar | FORGE | and of course VW
Old 09-02-2006, 11:55 PM
Grover's Avatar
Garland, TX, USA
I have read over and over that the K&N filters are actually bad for our cars due to the MAF being so sensitive. Apparently it has something to do with a small amount of oil leaching off the filter and onto the MAF which will cause it to fail prematurely (or something like that)...I will stick with OEM since I have also heard they are better than the K&N
Old 09-03-2006, 12:19 AM
captbp's Avatar
Lawrenceville, GA, USA
Car: 2000 Yellow GLS. 2.0, 5 speed
Veddy interesting responses. I have the same questions as Alan regarding the K&N air filter. I'll keep reading as they come in. Thanks everyone.
Bob
Trust your captain .... but keep your seatbelt securely fastened.
Old 09-03-2006, 04:31 AM
mel72349's Avatar
Randallstown, MD, USA
Car: 2006 TDI
I've been installing K&N air filters on my vehicles for many years. Carbs and FI, cars, trucks and motorcycles. Never had any issues with oil fouling up anything.
2K6 Dweezil DZL BTL
http://mefi.us/images/fuelly/sig-us/15472.png
Old 09-03-2006, 04:45 AM
GatorBeetle's Avatar
Wendy 1974-2008 :(
Salisbury, MD, USA
Car: '06 RS GLI 6-Spd
K&N on Hobbes for almost two years now...MAF is just as good as ever. MAF problems come in when the filter is cleaned and over oiled. I did the snowboxectomy and filter at the same time, saw a diff...did Magnecors about a month after, and saw more difference.
Put a K&N in my old Explorer...made quite a bit of difference in throttle response there too.
$60 is a bit much, and I have not been convinced of the worth of their oil filters yet.
Wendy Rotar 1974-2008
Online Memorial & Guest Book
Old 09-03-2006, 04:58 AM
manoverboard987's Avatar
Lurker Status Assumed.
Car: 2000 Jetta GLS 2.0L
i've had a K&N in my 2.0's stock airbox for a couple years now, and i just recently took it out for its first cleaning. there was no oil whatsoever on the clean-air side of the filter (none on MAF or in the tubes), and none on the dirty side either for that matter.
"recharging" the filter involves spraying some cleaner, running water thru it, letting it dry, and then respraying the oil. it's a relatively simple process, and i found it quite enjoyable.
i'd say it gives you a little bit more throaty noise, and the main place i found power improvement was when downshifting to accelerate at highway speed. there it helped a lot, and everywhere else it helped the power a little. of course, once i removed the snowbox, i noticed the improvement a lot more. (throatier noise, better top end acceleration, etc.)
as far as the K&N oil filter, i dont know anything about how they perform, but i wouldn't buy a K&N air filter just because you get an oil filter free.
i payed regular price for mine and it was $49.95, so it sounds like they're marking it up to cover the oil filter.
some say that the K&N plus snowbox removal is actually better for airflow than a CAI with the filter on the tip.
Old 09-03-2006, 05:11 AM
Wendy 1974-2008 :(
Salisbury, MD, USA
Reason I have heard given for this is that the stock airbox does a better job insulating the intake from hot engine air than a CAI, even one with a heat shield.
Old 09-03-2006, 06:02 AM
that makes tons of sense. nice thick ABS plastic is gonna transfer heat a lot slower than any kind of metal.
another good reason to get the K&N then.
Old 09-20-2006, 02:18 AM
Grover's Avatar
Garland, TX, USA
I am sure those of you using the KN filters are not having problems but I was reading the following over at tdiclub and I thought you might want to read it too...
http://forums.tdiclub.com/showthread.php?t=152289
Old 09-21-2006, 03:30 PM
Billsbug's Avatar
USA
IMO it's not worth 'cleaning' the filter, just get a new one every 25K.
Old 09-21-2006, 03:49 PM
BarefootHoodoo's Avatar
Can you dig it?
Durham, NC, USA
Car: 2000 GLS TDI aka "Shazzie"
One thing we have found with Foreign cars is this...stick with what they used when they built the car. Some of the aftermarket products don't work as well in the long run. Especially anything electrical. You may not have problems now, but a few years down the road, you might. I know some people might take issue with this, but this is what we've found to be true after repairing many Toyotas, Hondas, and VWs.
I'd rather be Bellydancing!!
Which Air Filter? CYBERGREENCC 1.8 Liter Turbo 3 06-26-2006 01:23 PM
FS: Eurosport Intake w/K&N cone filter, B&M short shifter NJ Turbo Market Place Archives 14 06-14-2006 05:56 PM
Air Filter Replacement larryziegler 2.0 Liter Gas 6 04-05-2006 12:23 AM
Air Filter black_bug 1.8 Liter Turbo 3 02-20-2006 06:59 AM
Air Filter Replacement docdixon 2.0 Liter Gas 6 09-26-2005 09:59 PM
