| Miscellaneous Hoo-Ha Archive Archived Threads from Miscellaneous Hoo-Haa |
Let me forst go on record as saying i have no experiance or have done any real studies on how satellites and other transmitting devices transmit signals.
First off, i think your directtv dish might need some fine adjustments go get it a better signal. [BS]Otherwise, i think it might have to do with how wide hte singnal is. the TV signal probably has alot wider signal wave than the radio, so most likey it has a harder time penetrating thru obstacles. [/BS] Thank you for reading this post that was mostly [BS]
I get a 88-90% signal with those, BTW. But XM, never gets messed up, unless I am deep in a parking garage. |
[BS]Like i said before, I think it has to do with how wide the wave of the signal is, TV waves are genreally wider than audio waves, and therefore would need more power to fight thru obstacles (walls, clouds) to reach the receiver. I could be 100% wrong about it. But that's just what i think.[/BS]
I can't explain the technical reason for it, but you are not alone. DirecTV does get affected by heavy cloud cover, while it I have never lost the XM signal regardless of weather conditions. It will be interesting to see if someone here knows why.
Hey TJ! When you're ready to post your question about sex I'll be here waiting to answer it!!
♥Amy♥ ♥06♥15♥08♥ ![]() ♥It doesn't matter where you go in life, it's who you have beside you ♥ "Put your troubles away until tomorrow. If you're lucky someone'll break into your house tonight and steal 'em" ~ Dean Martin Skittle & Me |
what it is, is that for Direct TV, you have to point the dish at the satelite, because the type of signal that comes from that satelite, is more of a directed type signal which is the same for any satelite that is has a dish for antenna. For XM, it is more of a broad spread out signal, such as GPS or Iridium satelites.
Sent from my computer via keyboard "Beets, Bears, Battle Star Glalactica"
It's a cybergrüen thing, you wouldn't understand |
(now let's see...it says here in the instructions, that slot 'a' goes into slot 'b' then....dang it, it's not as easy as it looks on the box...) |
| This question will never go away...................... | IgottaBug! | 1.8 Liter Turbo | 5 | 11-28-2005 07:48 PM |
| Question about oil changes | CoriBug | 1.9 Liter TDI | 9 | 11-26-2005 05:21 PM |
| Aux in question | The Cheat | Car Audio | 2 | 11-01-2005 05:03 AM |
| car bra question | zenewie | Styling Modifications | 2 | 10-21-2005 01:54 AM |
