Air Conditioner Repair - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > Archive > Miscellaneous Hoo-Ha Archive
Miscellaneous Hoo-Ha Archive Archived Threads from Miscellaneous Hoo-Haa
Old 06-14-2006, 02:30 AM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
Default Air Conditioner Repair
No, not fo the car. For my bedroom.
Anyone know how to fix em? Mine broke. I turn it on and it does nothing. I'm thinking of tearing it apart and giving it a god. Warranty is up. What do y'all think? Should i give it a try?
LOOK AT MY Bug!!!!
Old 06-14-2006, 02:39 AM
slugo's Avatar
Phoenix, AZ, USA
Car: YELLOW 2000 1.8
I don't know anything about them other than power, no power. I guess you cant do much more harm then has already happened. I say go for it.
Old 06-14-2006, 02:43 AM
bugsy98nb's Avatar
Bug Less
Toledo, OH, USA
Car: 10 Compass~95 Intrepid ~82 Bunny
JOhn you should be able to pull the front cover off, most of them have a filter in the front make sure that isnt Clogged up , also check to see if it has water laying in the bottom , its possible it froze up if theres a lot of water collecting on the bottom , if so you may have to tip it back some so the water can run out ..
~Jay~" L.E.A.K.O.I.L "Fo'Shizzle 12-21-2006"
Old 06-14-2006, 10:35 AM
Kickeroo's Avatar
STILL Can't Stop the Rock
Richmond, VA, USA
Car: 2000 GLS 1.8 Turbo
also, try just running "fan" for a while....if that isn't working, chances are that's the only problem.
2001 VDub Air Conditioner Motor ladyhawksguide 2.0 Liter Gas 16 11-08-2011 07:57 PM
Air Conditioner Compressor bad vwfleh Questions, Issues, Concerns, or Problems with the New Beetle 4 05-18-2006 11:48 PM
Air conditioner whisle savethebluths.org 2.0 Liter Gas 1 04-15-2006 03:06 PM
repair manuals? joshuah 1.8 Liter Turbo 5 01-22-2006 09:36 PM
Cold Air Intake CAI Ram air the Cheap way.... Pulgamovil Technical Modifications 11 11-05-2005 08:34 PM
