spray foam insulation - NewBeetle.org Forums
Old 07-02-2009, 03:33 AM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Car: 2006 KitchenAid Red NBC, '66 Ford Mustang
Default spray foam insulation
Anyone have this in their house? We are thinking of getting our attic sprayed. I was just wondering if it really makes a big difference? On friday we are getting new windows- low E with argon- hope those make a difference too. Our house faces East West and it is crazy hot on the back of the house in the afternoon.
Old 07-02-2009, 05:25 AM
OH, USA
Car: 03 GTI
Spray "foam"? Are you sure it's not "blown-in" cellulose-based (Green Fiber is the common brand)? If so, yes I have that--did it myself w/ a rented machine in my walls and attic--it works quite well, w/ 12" in the attic, new windows and doors my winter heating bills dropped 40% or so.
Old 07-02-2009, 01:22 PM
squeebug's Avatar
Magically Retarded
North Platte, NE, USA
Yeah they have this stuff they just spray in between the studs and it expands to take up the space. I've never used it and don't have it but I would imagine it works pretty good.
"Beets, Bears, Battle Star Glalactica"
It's a cybergrüen thing, you wouldn't understand
Old 07-02-2009, 01:26 PM
Think your house is hot? I lived in a house with NO insulation for 2 years. Ugh that was miserable...and expensive. Moving to our new townhouse was a whole new world...cold stays inside and heat stays out?!
Any insulation is good. I've heard good things about the spray-in insulation.
Old 07-02-2009, 01:53 PM
gforce1108's Avatar
Port Jervis, NY, USA
Car: 98 Beetle TDI
I have the under side of my house done with it... it's an 1850's one room schoolhouse that basically sits on a rock wall. Very little insulation was added when it was 'updated' (I use that term very loosely).
It made a big difference in the winter... the floor was always freezing unless there was enough snow to keep the air out.
The big advantage was the ease of installation - there's very little space under half the house and nothing is built to standard dimensions.
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW
04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust.
57 Beetle Oval Window Sunroof
2 powerstrokes, Thing, Fox, Dune Buggy......
Old 07-02-2009, 09:06 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
No the stuff I am talking about is spray foam, it expands when they spray it up on the top of the attic on the underside of the roof and on the walls.
Old 07-03-2009, 03:00 AM
OH, USA
Car: 03 GTI
Not sure in your milder climate, but here in Ohio "they" say it is better to make sure your attic is adequately ventilated and that you insulate the attic floor/(living space ceiling). Heat kills the roofing material, especially if you have asphalt shingles--you'd be blocking heat transfer out of the roofing mat'l into the attic space. I would not insulate my house that way. My attic has some soffit venting, gable end vents and ridge vents--I wish I could get even more in there. It would probably make your house cooler, but I'd also fear possible moisture/condensation issues and the reduction in the life of the roofing mat'ls.
Old 07-04-2009, 01:54 AM
kate_the_valkyrie's Avatar
Bobby's Mommy
Lake Havasu City , AZ, USA
Car: Bobby Gutz - '03 Red Color Concept
Im curious as to what this stuff is made from??
The insulation they always use here in the hot desert are just the fiberglass strips or whatever they are, the pink itchy stuff that looks like cotton candy. All the homes have the style of a crawl space/attic, but no one uses them and they just layer that stuff up there... and I'd love to upgrade the insulation if it will help the electric...
'I put my hands up on your hubs; when I dub, you dub, we DUB.'
Source for hood insulation clips FootScoot Parts and Accessories 12 05-11-2008 05:50 PM
Noise Insulation Panels D2Beetle Parts and Accessories 0 04-19-2008 06:56 PM
Spray-painting a checkerboard xXRockyHorrorsXx Paint and Body 4 12-28-2007 07:14 PM
Spray on bra pdoel Paint and Body 13 05-18-2006 03:13 PM
Hair Spray: Can You Dig It? Oyveychris Jokes 4 03-31-2006 12:40 PM
