Boot not locking without a hard push - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > New Beetle Convertible
Old 04-19-2017, 09:25 PM
Default Boot not locking without a hard push
Hi,
My boot opens from the switch & fob, but have to slam it hard to close, there is no obstruction far as I can see, any ideas please.
Thank you.
Old 04-20-2017, 04:54 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
what year is your car? Sometimes the striker or latch can fail, the latch needs lubed or adjustments can be made.
Here are some videos ; showing how to lube the latch and see if its working ok; they show sticking and not opening problems.
https://youtu.be/YDC1dw7g4II
https://youtu.be/bO7eYOcOlv4
Sent from AutoGuide.com Free App
Got a trouble code? Look it up; on the Ross Tech Wiki!
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Need to find a VW part number? Look up here: http://parts.vw.com/
Then, use google; to find the best prices! :-)
Old 04-20-2017, 05:03 AM
Convertible 2005.
Thanks
Old 04-20-2017, 05:05 AM
Thanks Billy, will try tonight.
Old 04-20-2017, 06:38 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Here is the service manual for the the convertible trunk/boot door:
http://workshop-manuals.com/volkswag...ce_and_repair/
Old 04-20-2017, 07:50 AM
Thanks
I don't have the turn lock on the outside, but assume the inside latch and mechanical parts are the same.
Ta.
Old 04-24-2017, 08:50 PM
Fairfax, VA, USA
This is NORMAL for the convertible. I have a 2003 since NEW and you have to slam the trunk.
I close the trunk about 1/2 way, the quickly push down but do not leave my hand on the trunk, I allow the inertia of my quickly pushing down on the trunk lid to close and latch properly. Been doing this for 14 years!
Old 04-24-2017, 09:01 PM
Wow 14 years, must really love it. Have you had much trouble with it over the last 14 years.
We have a 1.9tdi.
Would be good to know. Thanks
Old 04-25-2017, 01:09 AM
Fairfax, VA, USA
Absolute WORST car I have ever owned as far as problems. If it was not a convertible it would have been gone a LONG time ago.
When things are working right it is fun car to drive, but do not get me started with everything that has failed/worn out on this car.
Luckily it is still running pretty good. Have tanken it on a few 1100 mile direct road trips that took about 14 hours as well.
Old 04-25-2017, 01:47 PM
What's the mileage now? Our one is a diesel and hoping as they get older the parts get cheaper... I can only dream :grin:
Old 04-26-2017, 01:04 PM
Jeff2's Avatar
OH, USA
Car: 2005 Cabrio GL
On our '05, the little trunk hatch is a bit hard to close. We just push down on the VW emblem since it's so big and gives a nice spot to push on.
Ours is a pain to keep going as well. Replaced the driver's door latch (broken microswitch) two weeks ago, fixed the glove box door (glued the handle back on and replaced the "bump stops" with "super magnets" to keep it closed), now the vynil on the inside driver's door panel has pulled away from the panel at the top. The "little things" never end with this car. Everything that's made of plastic is breaking on the thing. Ugh.
But, it is fun to drive, despite the massive blind spots caused by the convertible top.
2005 New Beetle Convertible GL, 2.0 liter gas (BEV), 80k miles
Old 04-26-2017, 11:39 PM
Fairfax, VA, USA
My car has around 101000 miles at this point. 1.8t 6 speed Tiptronic transmission.
I will say the 1.8t can be a durable engine. The stupid sludge problem, I have cleaned replace the oil pick up 2 times, but the thing keeps running. Transmission valve body, door latches, passenger side once, drivers side 2 times, both front axles, alternator overrun pulley, water leaks, rear window regulator cables, you name it, I have had issues with it.
When the car is working and running well, which is generally does, it has never left anyone stranded, it is fun to drive even if people think I look funny in the car. But the top goes down, so I cruise it with the top down when ever I can.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
hard to shift into first and second gear and clutch is hard to push in w3073985 Questions, Issues, Concerns, or Problems with the New Beetle 1 02-13-2015 12:27 PM
Hard to push shifter down into reverse Sarahalilbit 2.0 Liter Gas 4 04-07-2014 06:14 PM
Not Beeping When Locking, Not Electonically Locking Hood swell Questions, Issues, Concerns, or Problems with the New Beetle 4 10-10-2007 12:21 PM
Need a push AmyJane Jokes 0 09-08-2007 05:00 PM
Boot locking problems! lewishere The New Beetle Experience 15 01-12-2007 10:57 PM
