Rear Brake Bulb Replacement - NewBeetle.org Forums
Old 11-09-2006, 06:21 PM
Default Rear Brake Bulb Replacement
Anyone know how to get to the tail light bulbs so I can replace the brake or indicator light bulbs?
Looks like VW have gone out of their way to make it impossible to get to the things without special tools.
Thanks.
Old 11-10-2006, 12:18 PM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
No tools needed.
NBs: Round plug inside trunk pops out.
NBCs: Grille-looking rectangular panel pops out.
Reach in and you'll feel a large finger-grippable nut, back it off (DON'T DROP IT) and place it somewhere retrievable. Take a small-flat-bladed screwdriver and wrap it in cloth so you don't scratch the paint. Poke said protected blade between the inside body joint and the tail light, gently pry tail light out. Remove offending bulb, replace with new. Installation is, as they say, the reverse of removal.
So easy, (sorry, Geico), even a caveman can do it.
Old 11-11-2006, 07:38 AM
LadybugEwa's Avatar
Bug me again!
Toronto, Ontario, Canada
Car: 2012 Turbo, RED of course!
Instead of the towel-wrapped screwdriver I used a sturdy plastic knife and fork to pry the taillight out. They worked great! I was worried about scratches, since the tail light needed quite a bit of leverage to get unstuck. Once the whole taillight is out, you have to pull off 2 plastic parts where the wires go, to disconnect taillight from bug. Then to take the bulbs out, it's just a half-twist of the female plastic part you unplugged the wires from. I hope that makes sense.
Here's a look at Ladybug
Old 11-11-2006, 11:22 AM
Duffy's Avatar
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Lightbulb Tip
Don't completely remove the holding nut inside the car. Leave it about two turns on. When the tail light assembly releases, it won't fall out and damage the car or the assembly. Also, use a plumbers helper to pull out the assembly.
Tom
Old 11-12-2006, 01:08 PM
SJBug
Clinton Township, MI, USA
Car: 2000 Cyber Green 1.9 TDI
Talking Brake light Lamp replacement a breeze!
Ok, I'm going to give this brake lamp replacement a try today!
Just got done and it was an easy job. Thanks for the help in this regard. Reading the posts on this topic made all the difference.
I used some dielectric grease on the bulbs and put a tad on the retaining clips so that the lenses went in easily and hopefully out easier next time. I replaced both tail lamps today so hopefully they will last.
Thanks again!
Old 01-30-2009, 04:27 AM
JLasvegas's Avatar
Las vegas, NV,
Car: 2002 black 2.0 5 speed
what type of bulb does it take?
Old 02-26-2009, 04:16 PM
squeebug's Avatar
Magically Retarded ™
North Platte, NE, USA
u can also use a plunger to get the light out. stick it to the light and pull it out, no screw driver or anything else to worry about scratching paint.
Sent from my computer via keyboard
New Car Fund
"Beets, Bears, Battle Star Glalactica"
It's a cybergrüen thing, you wouldn't understand
Old 03-08-2009, 01:03 AM
JLasvegas's Avatar
Las vegas, NV,
are they 2057 bulbs?
Old 05-01-2009, 12:11 AM
Casperturbo's Avatar
Casper, WY,
Car: '03 GLX
Nice tip on the plunger, worked great.
I just replaced mine and it's a standard bulb 1157. Two filaments, one for lights and one for brake light. Bayonet style.
Old 05-20-2009, 03:49 AM
riverratmike's Avatar
Lake Havasu City, AZ, USA
Car: 2005 2.0L Beetle Hard Top
do all new Beetles use the same brake light bulb. Will the 2057 or the 1157 work ok with my 2003?
Old 05-23-2009, 04:56 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
You need the dual filament 1157 as Casperturbo suggested
SoCalnewbeetleclub
Old 05-25-2009, 02:55 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
Car: 2000 2.0L Red New Beetle GL
i've gotten the tail light out, but can't seem to get it back in!!! help lol.
Also there is some spring/black plastic rod like thing poking out from the inside, anyone know where that is supposed to go?
Old 05-25-2009, 04:41 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
never mind. just got back from auto zone. Tail lights working properly
only thing... the mechanics who last worked on my tail lights broke the teeth on the bulb housing piece so they aren't sitting as secure in the tail light as they should be. Have to go to the audi/vw part dealer for that though
Old 09-13-2009, 01:43 AM
San Diego,
Car: 1999 TDI
Default Replacing tail light assembly
Put the retainer spring's flat tail into the slot near the bulbs first. Skinny wrists will help get your hand behind the tail light assembly to do this. (Be careful of the paint with the assembly as you do this.) After you get the retainer spring in place and your hand out, the tail light assembly goes back in on outboard side first. Then push the edge in a little bit on the inboard side to snap in place. Doesn't take much pressure to seat the assembly. Put the interior knob back on to secure the assembly and press in the plastic access panel. My access plate doesn't snap in. I had to turn it a little once the tabs were in place. Then it was secure.
Old 04-13-2010, 12:26 AM
VW fanatic
St. Louis, MO, USA
Car: 2005 Dark Flint Cabriolet
Red face '05 NB Convert tail light bulb replacement
2005 Convertible--Dark Flint Edition.
Left rear tailight / signal bulb replacement.
1. Found rubber plug, removed it.
2. Found a small T-shaped metal ( not star-shaped plastic which shows in manual) wing nut, lossened it. Not knowing how to remove assembly, I decided to quit while I was ahead. Now I know how to get the assembly out and change the bulb, and I'll give it a shot.
3. On the passenger-side, however, there is no round plug/hole.
How would you get this side out? Anyone experienced this?
4. Does the whole plastic inside liner, with "vent grilles" on the inside of luggage compartment at rear of vehicle need to come out?
any help appreciated. sure is complicated just to change a bulb! In contrast--I own a 1959 Beetle, and there is one small screw on top of the tail light housing that comes out! times have changed--in the VW Dealer's favor!!!
cheers.......
Old 04-13-2010, 11:56 AM
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
Yes, there is. Get a flashlight and look again. Nothing else, not the liner, not the vent grille, nothing, needs to be removed.
When I wrote the original instructions 3-1/2 years ago, I was referring to the passenger side.
Old 04-13-2010, 12:02 PM
Duffy's Avatar
Jonesboro, AR, USA
cheers.......
Yes, that is what you remove. The grilles pop out from either the bottom or top. Just don't break the retaining tabs.
Old 12-07-2010, 04:29 AM
Noob
San Pedro, CA, USA
Car: 2007 convertible
Just attempted this myself over the weekend and discovered the 'teeth' were almost all gone on my '07 NBC, and the lens was separating from the housing....
Old 02-07-2013, 04:28 AM
Plunger for the win!
Thanks for a great tip!
Old 03-08-2013, 01:45 PM
That is a terrific idea using a plunger. My hands and wrist are to big to get in there and so i usually have to have my wife do it..lol
Orange Park Volkswagen
Headlight bulb replacement Buglover Technical Modifications 16 11-03-2006 02:20 PM
Headlamp bulb replacement CYBERGREENCC Questions, Issues, Concerns, or Problems with the New Beetle 4 10-31-2006 01:38 AM
Fog bulb replacement Jeramiah Technical Modifications 3 08-30-2006 07:50 PM
Rear Corner Light Bulb Replacement enahs95 Paint and Body 1 12-28-2005 06:18 PM
foglight bulb replacement on 99 new bug E-AT_me Questions, Issues, Concerns, or Problems with the New Beetle 2 10-30-2005 01:10 AM
