Anyone notice this? - NewBeetle.org Forums
Old 01-09-2007, 04:56 PM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
Car: '06 NBC Harvest Moon - Manual Trans
Default Anyone notice this?
Using the all windows up button, my headlights dim.... is that normal?
Old 01-09-2007, 04:57 PM
niki's Avatar
#1 Auntie
CA, USA
Car: Former owner of Bugzzi ('99 White GLS), new owner of '10 Civic LX-S
Mine do this a little bit... it's because you're draining battery power I think.
If you ask for more patience do you think you'll simply get more patience?
No. You'll get an opportunity to be patient.
Old 01-09-2007, 05:00 PM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
Makes total sense... just making sure, since I'll be bringing in my car for it's window issue soon... may as well make the trip worth my while.
Here's another.... My stick shift knob is rotating... so the numbers do not correspond to the gear location anymore....
Old 01-09-2007, 05:03 PM
Beetlemania's Avatar
crank it up, suckers!
Broken Arrow, OK, USA
Car: 1999 Silver Aero GL
The shift knob is just stuck on a metal lever, held on with a clip. You can just rotate it back!
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings!
Mi Bacca es Chewbacca!
I'm one of those people. Whatever that means.
Old 01-09-2007, 05:09 PM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
I dont' think I have enough elbow grease... I may mention it to the service dude. It's not affecting anything, just pesky passengers bringing it up.
Old 01-09-2007, 05:18 PM
Oh yeah, I just remembered that the stock knob (you've still got the black rubbery one, right?) is shaped inside to keep it from twisting. It might be kind of hard to get back in place...
Sorry, it's been a while since I changed mine out!
Old 01-09-2007, 05:20 PM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
Yeah, I have the stock one... never changed it for another.
Old 01-09-2007, 05:46 PM
noR's Avatar
Administrator
Jackson, MS, USA
If the shift knob is spinning; then call it a safety hazard and explain how it's caused you quite a few scares. (fib)
If it's 'just the plate/numbers' that's spinning, you could:
a) tack it in place with the itsy-est/bitsy-est dab of superglue.
b) spin it, bat it around, play with it when you're at stop lights until it pops out, then glue it back into place.
c) take this opportunity to replace it with something more unique, like a vw logo or personal picture or graphic.
If the whole knob is spinning though, make the dealership fix it.
noR | me | Phrog
PHROG
Old 01-09-2007, 05:58 PM
It wouldn't be just the shift pattern plate. That's held in with 2 clips, fitted into holes in the knob. noR has a point, you could easily claim this a safety issue, though I don't think it will actually risk any damage. But I don't understand how it would start spinning in the first place. It's hard plastic under the rubber, and it's got a flat spot that corresponds to a flat spot on the actual shift lever.
Old 01-09-2007, 06:42 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
I dunno luv, when I use that bloody button it just makes me lip curl up.
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 01-09-2007, 09:42 PM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
You're funny!!!
Old 01-16-2007, 03:46 PM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
I'm having them check out the gear knob position too while it's in getting the window fixed today.
Old 01-16-2007, 03:49 PM
Hope it's an easy fix!
Old 01-17-2007, 02:29 AM
ViningsGal's Avatar
Bailey Bug!
Atlanta, GA, USA
They have ordered a new knob for my beetle. The 2006 doesn't use a clip to hold it in place, but a "v" shaped notch that the knob fits into... apparently the knob I have had a misaligned notch (this is all what the service rep is saying). So I'll likely have it replaced on Friday.
Old 01-17-2007, 04:32 AM
Hmph! I never thought about a difference in knobs between model years!
I like parentheses (in case you didn't notice) Beetlemania Miscellaneous Hoo-Ha Archive 113 08-17-2007 12:04 AM
Safety Recall Notice-N4 rzalone Questions, Issues, Concerns, or Problems with the New Beetle 7 12-12-2006 04:35 AM
ever notice..... CyberGypsy Miscellaneous Hoo-Ha Archive 29 02-25-2006 06:04 PM
If you notice anything funny... jcroft Suggestion Box 7 09-29-2005 04:03 PM
