Alarm,Lights,Windows,Trunk won't work.... - NewBeetle.org Forums
Old 05-22-2009, 04:27 PM
Post Alarm,Lights,Windows,Trunk won't work....
Hi All,
Yesterday I walked to my car as usual and the first thing i noticed was that my alarm key wasn't working, Then i opened the car with key, the light in the lock seems to flicker.
next thing i noticed is that the windows won't roll down and the trunk wont open with the key.
and also the consul light wont come on when the door is open. yet. the lock buttons on the inside do work.
i checked all the visible fuses in the box next to the driver side with a fuse detector and they all seem to be working.
so if anyone has any idea what it please help before i take it to the mechanic...
is it a bigger fuse inside the car? is it the computer? i have no clue.
thanks,
photography bug
Old 05-22-2009, 05:12 PM
MichelleRoze's Avatar
Auburn, Georgia, USA
Sounds like a battery issue. Check the voltage of your battery. My mom has a convertible and when her battery was just slightly low...the top wouldn't go all the way down. There wasn't enough voltage for it. So maybe the reason your key isn't working is because there isn't enough voltage in your car battery to activate the commands you are telling it. I believe locks will work for awhile since it doesn't take that much power. Try that first, may be as simple as that.
"Probie"
2k12 ToD Checklist
Dub Gestapo
Old 05-22-2009, 05:21 PM
Default hey!
i will make sure to check that with the mechanic!
Old 05-22-2009, 06:31 PM
Car: 2001 GLX 1.8 Turbo - TechnoBlue
I know you said you checked the fuses, but your symptoms sounds Exactly like a blown fuse #14.
I've replaced mine a dozen times, even went so far as to get the new fancy fuses that have an LED that lights up when the fuse is blown so you can see it as soon as you open the panel.
Here is an old [post with a picture of the fuse panel.
I'd replace #14 just for the fun of it.
FUSE BOX--> need HELP PLEASE
Old 05-22-2009, 08:43 PM
Default printed!
and will take to mechanic!
thanks again!
Old 09-07-2009, 05:05 PM
I have a 2000 beelte that keeps blowing fuse 14. Even when the car is off and the key removed.
If you figured this out could you please email me
randall@bisonit.com
Tags
alarm , electric , fuse , key
Alarm went off and Trunk Light stays on and won't go off Poodlebugz Questions, Issues, Concerns, or Problems with the New Beetle 11 01-28-2010 01:17 AM
windows, sunroof, trunk, interior lights wont work xXRockyHorrorsXx Questions, Issues, Concerns, or Problems with the New Beetle 0 01-02-2008 04:54 PM
no alarm/windows/hatch/interior lights quangreybug Questions, Issues, Concerns, or Problems with the New Beetle 1 07-25-2007 12:30 AM
Condensation in all windows & wet trunk Nounours Questions, Issues, Concerns, or Problems with the New Beetle 8 10-08-2006 07:45 PM
Help...alarm went off key no longer puts windows up!!! lady bug 2.0 Liter Gas 0 09-06-2006 10:56 PM
