Top will not go down - NewBeetle.org Forums
Old 06-27-2010, 03:56 PM
KY,
Car: 2006 NBC
Default Top will not go down
I have a 2006 NBC and the top was working fine and one time we put it down and then it would not go back up. I can put it up manually, it seems like there is something running when I use the switch but nothing happens any help is appreciated, thanks.
Old 06-29-2010, 05:27 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
All window/top operation are connected. Try running the all windows up and down switch (relay reset). This often happens when there has been a fluctuation in battery current. This trick also works if the windows are acting funny.
SoCalnewbeetleclub
Old 07-01-2010, 03:29 PM
KY,
Car: 2006 NBC
That did not work, when I use the switch there is a running sound from the passenger side in the rear but nothing happens. I am lost as to what it could be.
Old 07-02-2010, 01:50 AM
KNEWBUG's Avatar
KNEWBUG
Thousand Oaks, CA, USA
Car: 2003 NBC GLS
Smile Check the fluid in the pump
I had a sucking sound and found that all the fluid came out of the pump into the spare tire well. You can not raise or lower the top manually without releasing the pressure in the system with the knob on the pump. The rubber gasket on the left side in the trunk is the cover to check the fluid level in the pump. Give this a look to see if the pump has fluid.
KNEWBUG
2012 BLACK TURBO LAUNCH EDITION
Old 07-02-2010, 02:55 AM
miffmole's Avatar
NBC Driver
SC, USA
What kind of fluid goes in there?
Old 07-02-2010, 03:40 AM
KNEWBUG's Avatar
KNEWBUG
Car: 2003 NBC GLS
Smile Fluid
Its filled with hydraulic fluid that runs through the lines that lower and raise the top
Old 07-02-2010, 03:51 AM
KNEWBUG's Avatar
KNEWBUG
Car: 2003 NBC GLS
Default The PUMP
Here is what it looks like in the trunk on the drivers side
Old 07-02-2010, 03:53 AM
miffmole's Avatar
NBC Driver
SC, USA
Great photo...thank you.
I'm assuming that there is a VW-approved hydraulic fluid that goes in there, right?
Old 07-02-2010, 03:56 AM
KNEWBUG's Avatar
KNEWBUG
Car: 2003 NBC GLS
Smile ????????
That I do not know, my pump was replaced after having the car two years. Covered under the warranty.
Old 07-02-2010, 12:14 PM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
Well, it does show a marginally-low level of fluid. Fluid should never get that low, so I'll assume a leak out of your reservoir.
What an excellent question... what type of fluid is approved by VW? I think a call to the dealer is in order, that way we'll all know henceforth.
Old 07-02-2010, 02:25 PM
miffmole's Avatar
NBC Driver
SC, USA
OK, I found mine inside of a little black plastic box...
Wonder what this is (on your photo)? (see circle)
It seems to adjust about 180 degrees. Mine was turned sideways, whereas, yours is straight up. Is this related to my problem of not being to put the top all the way down on the 1st try?
Old 07-03-2010, 12:37 AM
KNEWBUG's Avatar
KNEWBUG
Car: 2003 NBC GLS
Smile From the Owners Manual
instructions for what that screw does....
Old 07-10-2010, 01:27 PM
kissfish's Avatar
uk member
United Kingdom
Car: 2005 cabrio sports
Yes there is its your vw power steering fluid. Oh and also to fix your hydraulic pump for the roof to work just turn the screw to the right until you feel it tighten.hydraulic pressure resumed Job done
I love going topless......
Old 07-14-2010, 04:51 PM
bugsy98nb's Avatar
Bug Less
Toledo, OH, USA
Car: 10 Compass~95 Intrepid ~82 Bunny
wonder if you could leave the valve in the manual setting this way you could use the top ( opening manualy of course) untill you can get the problem fixed. I never had this problem with mine course it had a manual top .
~Jay~" L.E.A.K.O.I.L "Fo'Shizzle 12-21-2006"
Old 07-15-2010, 05:28 PM
KY,
Car: 2006 NBC
So far I cant get the top to go down, I can put it down manual though. It almost like something is not engaging to let it go down, I was hoping to fix it without a trip to the dealer but I dont know.
Old 09-11-2011, 02:39 PM
What did you end up doing to fix it?
Major Issue with the hydraulic pump on VERT TOP due to closing top manually phuzylogik New Beetle Convertible 18 08-24-2011 09:12 AM
Help! Top won't go up lovethesun123 New Beetle Convertible 2 10-14-2009 11:52 AM
When Do You Put Your Top Down? miffmole New Beetle Convertible 8 07-15-2008 04:51 PM
Faded Top silverhaird New Beetle Convertible 12 06-16-2007 12:49 AM
To Top, or Not To Hopkins The New Beetle Experience 17 02-28-2007 06:56 PM
