Manual Top Issue - NewBeetle.org Forums
Old 07-31-2010, 02:58 PM
qweencass's Avatar
Peace , Love , Bug'n
Portland, OR, USA
Car: New Beetle 05 vert mellow yellow
Default Manual Top Issue
I just purchased this vert from a private party and it had only two issues. One was the inside liner of the top is coming apart from the window. Looking through past posts it looks like a common issue and the pins will do the job. Thanks guys!!!
The second is when I put the top down and click it in the sensor warning light in the car does not detect that the top has clicked in all the way so it beeps and beeps. I know that the top is clicked in all the way. It beeps everytime I accelrate which is so annoying.
Has anybody had this problem before?? Or does anybody know how to turn the annoying beeeping off for now?? I am going to take it to the dealer but just wondering if anybody has heard of this.
Other than this love love love love looooovveee my vert....
Former VWs:
1999 Jetta Silver
2001 1.8T Beetle Vortex Blue
2007 2.5L Rabbit Shadow Blue
2005 N Beetle Vert M Yellow
Old 08-04-2010, 01:19 PM
VA,
Car: 03 Turbo S Convertible, 10 Tiguan, 63 Beetle, 98 Jetta TDI
^ Don't waste your time on the clips...clear silicone bead in the plastic receiver ring ON THE WINDOW...snap it back in and leave her top up for 24HRs...done! As far as your top beep, find someone with VAG-COM and check the convienence module to pin point what's causing the ecu to not see the top's down.
Old 08-05-2010, 03:52 PM
qweencass's Avatar
Portland, OR, USA
Thank you for the suggestions Im going to have my huband try the silicone do you know if you can get it at the home depot???
I think Im gonna take the car in to the dealership about the beep issue I dont know anybody else that can fix it for me otherwise.
Old 08-10-2010, 05:06 AM
VA,
^ Yes Home Depot/Lowes/Ace Hardware, etc. all sell clear silicone. Just get the squeeze tube (like toothpaste)...it's easier to use than the caulk tube. And make sure it's pure silicone (not the tub or tile kind).
Old 08-11-2010, 04:01 AM
qweencass's Avatar
Portland, OR, USA
Default Thank you Rugsux
Okay so I bought the silicone glue and did my back window yesterday and waited 24hours to see if it came apart again and guess what???? It worked thank you so much for the suggestion. My husband was so pround of me for fixing it myself and since my fingers are smaller it was better off that I fixed it anyway. As far a the manual top sensor issue I explained before well I guess it was the sensor just below the lock and it popped out so he pushed it back down with a screw driver and now that is perfect as well....Im so happy it all worked out and I owe most of it all to the org....thanx for all your help
Major Issue with the hydraulic pump on VERT TOP due to closing top manually phuzylogik New Beetle Convertible 18 08-24-2011 09:12 AM
Manual top latch shellbug New Beetle Convertible 3 12-24-2008 07:49 PM
Top issue AGAIN! JessBorck The New Beetle Experience 0 05-16-2008 08:42 PM
Need expert advice on top issue Susie F. New Beetle Convertible 24 11-21-2007 12:36 PM
Window drop/top damage issue update!! blackonblack New Beetle Convertible 12 06-04-2006 04:52 PM
