Adding non VW Fog Lights - NewBeetle.org Forums
Old 11-05-2010, 12:51 AM
2010BeetleConv's Avatar
Myrtle Beach, SC,
Car: 2010 Beetle Convertible
Default Adding non VW Fog Lights
Just wondering if anyone has added non VW fog lamps to the New Beetle. My dealer wants like $600 for the job. I was gonna get some nice lights at the auto store and try and install as part of the grill myself. I'd just have to add an extra switch to the dash I guess. Anyone done it. What lights did u use? Pictures? I want to get something that is small and looks nice.
Old 11-05-2010, 01:01 AM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
Buy fog lights that have a built in relay, a decent mechanic that can follow instructions can install them. There are thousands of light makers, JC Whitney has some relly nice lights,you will just have to pick the set out you want. Get lights with glass, plastic fades.
Old 11-05-2010, 11:10 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
ECS Tuning sells a fog light kit. I installed the OEM fog lights in my 2009 NBC for about $250. Installing the fog lights and grilles is the easy part. Purchased the fog lights and grilles from 1st VW parts. Euro switch off eBay for $15. Also had to buy the fog light connector (H11) for the bulbs (ebay for about $10). Went to the junk yard and got a wire with connector off a donor car for the fog light wire coming from the light switch. Just plug into the light switch socket. Find a way to run this wire (you will need to add appropriate length to it) down to the fogs. Find a close by ground point too. If using OEM fogs, a relay is not required, the switch is all you need. Remember too, doing it this way, the fogs will be active when brights are selected. Normally the fogs will turn off with brights on. On my installation, I used the OEM wiring method which is very involved.
Tom
Old 11-05-2010, 12:31 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Old 11-05-2010, 03:29 PM
Now we're talking!
Most offroad / truck shops that install lights and winches would do a better job than an average garage and would probably do it in way less time for cheaper.
Old 11-05-2010, 10:28 PM
Myrtle Beach, SC,
Wow, very nice. Not sure the vert will be doing any off raoding but those pics are nice. I was looking for some advice on smaller fog lights I can put thru the existing plastic on the bottom of the front bumper. I cant see at night.
Adding Footwell Lights alphaomegapi Technical Modifications 44 04-19-2012 03:18 PM
Adding Fog Lights to a 2009 Duffy Styling Modifications 6 08-31-2009 11:11 AM
adding fog lights DPsLuvBuggie Paint and Body 16 08-13-2008 10:58 AM
Adding OEM Fog Lights mel72349 Technical Modifications 0 08-02-2006 06:34 PM
Adding OEM Fog Lights mel72349 Questions, Issues, Concerns, or Problems with the New Beetle 0 08-02-2006 03:23 AM
