Auto-Dimming Mirror Installed and Working. - NewBeetle.org Forums
Old 12-04-2010, 01:41 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Thumbs up Auto-Dimming Mirror Installed and Working.
Just finished installing my auto-dimming mirror (eBay) in my 2009 NBC . It was plug and play. After studying the wiring diagrams (Bentley) led me to believe that the wiring for auto dim mirror functions were not brought up to the mirror connector T8. To my surprise, all wiring was there! It only took me 18 months to find a tan convertible auto-dim mirror.
Tom
Old 12-04-2010, 04:05 PM
MyOtherRidesAVette's Avatar
Thumbs up Excellent!
Congratulations!
Here's a tip on p&p upgrade items. Think about what the item is. Is everything needed for the upgrading self contained (such as the sensor on the backside, facing forward, side of the mirror). Does it only need power to operate and does what is already there only need power? Vol'a!!!! In this situation no additional wiring is needed in the harness.
Now if this were a different vehicle and the new mirror had " outside temperature", it might reuire a different wiring harness (or simply adding one lead from the sensor unit), and would definately require the addition of the sensor.
Most auto manufacturer's today install wiring harnesses which will accomodate most options, I do know of rare exceptions.
MORAV
In der Automobil-Scheune
Old 12-04-2010, 04:16 PM
ricaroo's Avatar
Rick
NH, USA
Car: 2007 NB Convertable triple Beige
what is an auto-dimming mirror ?
Everything works out in the end, if it hasn't worked out,then it's not the end.
Old 12-04-2010, 04:43 PM
The mirror dims (darkens) at night automatically, instead of you having to flip the lever in the center bottom of the mirror, so headlights behind you aren't glaring in the mirror. There are also outside mirrors that have the same feature, but NOT available for the Bug.
It woks through a sensor on the back of the mirror (the facing forward side) that senses outside light, and turns the feature on, just like one that turns outside lights on when it gets dark. Almost every car manufacturer uses mirrors made by Gentex. Go here to learn more or buy new: http://www.gentex.com/automotive.html
MORAV
Old 12-04-2010, 04:52 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
ricaroo: An automatic dimming mirror is one where lights from the rear are sensed by the mirror (photocell) and will dim or darken the mirror using electrochromic technology (liquid crystal). Also, the AD mirrors have enhanced interior lighting characteristics which are nice. No levers to flip. Its worth upgrading to one. Grey AD mirrors are less rare than the tan.
MORAV: What wires I thought would be deleted were the reverse inhibit, lights on and switched power. Bentley manual indicated that these are installed if an AD mirror was installed. I had already found a workaround to be install in the mirror, but won't need it now.
Old 12-04-2010, 05:04 PM
Thumbs up Right On!
Yes I'm familiar with all the technical turms you are referring to, I was trying to keep it "lay"man. And you may be right, they may now be using sensor,s in the mirror facing rearwards. My GMs are all early versions with the sensor facing forward sensing daylight. Thanks for the update. I'll go to my own link and learn more.
Thanks,
MORAV
Old 12-04-2010, 05:07 PM
Exclamation More Info
I believe that would be the lead to turn on the light when the doors are opened. There would still need (as you discovered) an always "availabe" power lead to enable you to manually turn on the mirror at the mirror switch, which would be the same power source as the self-dimming feature. Haven't seen the Bentley schematic so I can't say why you might have been confused or perplexed.
MORAV
Old 12-04-2010, 07:56 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
MORAV
No. This is from the headlight switch circuit. I think it just powers the two little red LED's that shine down on the dash. Nice... The wires for the door interior light are there.
Old 12-04-2010, 08:55 PM
Thumbs down Wrongo Buckaroo!
Wrongo buckaroo. Different mirror in a Vert. Since there is no "dome" mirror in a Vert, it is replaced with a light in the bottom of the mirror. The only console light is up under the radio head portion of the dash console shining down on the center console cups holders/ashtray/powerpoint/cigarete lighter. And it is controlled by a self contained switch (power always on) to mirror. And if you read the OP is was done to a NBC.
The "vert top" status indicator is also included in the mount portion of the mirror, to the right of the clock, which you do not have in a hardtop NB, although you would have constant power to the point of the clock with the ignition switch on, so on second thought, this would probably the power sourch for the self dimming feature, as it does not need to function with the ignition switch off.
MORAV
Old 12-04-2010, 09:00 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Never said "dome" light.
Old 12-04-2010, 09:03 PM
I've updated that post to include some other thoughts, but those led lights don't exist in the NBC. The "map" light does because there is no other cabin lighting. I can't tell you what is in yours, only what is in mine. And the logic behind engineering design. Or the way it should be! (lol)
MORAV
Old 12-04-2010, 09:12 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Only the auto dim mirrors have two little red lights that shine down on the dash. As far as the under dash or ashtray light, it was deleted sometime in the past. Sense the hole was there in my 09 NBC, I had to put something in it. I got one for the local salvage yard, but modified with three bright red LED's instead the one.
Old 12-04-2010, 09:24 PM
Do the auto-dims also have the "map" light?
Old 12-04-2010, 09:28 PM
The cabin lighting in the NBC sucks, and is non existent in the back. I'm thinking of adding some kind of door operated lighting in the rear panels if I can find something that looks factory. Maybe two "dome" lights, one on each side.
The real down side is that my Grand-Daughter can't see to put on her seat belt and has to ride back there because in the State of Texas she has to be in a child seat, in the back seat, until she is seven. Sucks and is stupid!
Any ideas or thoughts?
Old 12-04-2010, 09:33 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Yes, the AD mirrors have the map lights in the bottom of the mirror, with this difference. There are two lights with separate off/on buttons for the driver and passenger, but both lights come on with the door.
Back seat lighting or lack of is a problem. I know of no good solution for that.
Old 12-04-2010, 09:52 PM
Do each of the map lights have three position switches door/off/on, like the single map light?
Old 12-04-2010, 10:16 PM
Palmettoguy's Avatar
6 Is Better Than 5 ;)
Boston, MA, USA
Car: 2002 Blk TS
MORAV
My "Hardtop" beetle has a map light under the rear view mirror...Guess I'm special
Old 12-04-2010, 10:30 PM
Zann's Avatar
HP Technician
Macon, GA,
Car: 2002 New Beetle Turbo S
You must have a sun roof
Old 12-05-2010, 02:27 PM
Boston, MA, USA
Car: 2002 Blk TS
Nope...Although that would be nice.
Window, door lock, mirror not working Dverdin 1.8 Liter Turbo 8 10-06-2011 04:04 AM
Mirror Switch still not working... RandyN 2.0 Liter Gas 3 05-05-2010 10:22 PM
Did the TS ever come with an auto dimming rearview? afinley Styling Modifications 6 01-25-2008 04:05 PM
Anti Dazzle - Auto Dimming Mirror install help diabolique Technical Modifications 5 09-20-2006 07:49 PM
Auto-Dimming mirror swap diabolique Styling Modifications 0 06-13-2006 06:34 PM
