Top Latch (Lock-Down) Sensor - NewBeetle.org Forums
Old 01-29-2011, 10:50 PM
overlander64's Avatar
Anna, IL, USA
Car: 2007 New Beetle Convertible
Default Top Latch (Lock-Down) Sensor
I have been having a continual issue with the sensor that monitors the top up lock-down status. The car is certain that the top isn't locked dowm properly yet it is locked down. I have tried running the top through its complete range of motion multiple times and the top-down sensor works properly while the top up sesnsor does not. Any idea whether I need a new sesnsor (and if so where it might be found) or if there is a sensor that needs adjustment? The car is a 2007 New Beetle Convertible with electric top.
Kevin
Kevin D. Allen
2007 New Beetle Convertible -- Gecko Green with Tan Leather and Top
Also own 1975 and 1984 Cadillac Eldorado Convertibles;
1960 Studebaker Lark & 1965 Dodge Coronet 500 Convertibles
Old 01-30-2011, 02:47 PM
bigcoyote's Avatar
Mesa, AZ, USA
Car: 2004 GLS
My wifes 2004 did the same thing - I was told several things about the top up sensors ( I was told there are 2 ) - bottom line - the dealer replaced one of them and it solved the problem. I believe they are located in the windshield header and may or may not be adjustable ( I have heard both ) - I have also heard that cleaning them with something may help??
According my paperwork switch is a -- 1YO-959-699-A and cost $ 20.19 at my dealer however labor was $ 220.00....
Again my wifes NBC is a 2004 and your part # may be different
Good luck
John & Juli
2004 GLS convertible
2.0 tiptronic
http://www.flickr.com/photos/bigcoyote/
Old 01-30-2011, 03:11 PM
MyOtherRidesAVette's Avatar
Exclamation
I was sure I posted this yesterday; must be loosing what little mind I have left! lol
There are several threads around here addressing this issue. As I remember, (1) sensor (on the passenger side, as stated, in the window header), there would be no need for a second. The second referenced may be the one for the down position. In one thread is mention of a VW Service Bulletin that, from my undersatnding of the read, includes the addition of a rubber, Dealer add on piece for centering (Dealer Fix). You might want to do a thread search and see if you can find additional information.
MORAV
In der Automobil-Scheune
Have a bad door lock/latch module? HudsonValleyVDub Questions, Issues, Concerns, or Problems with the New Beetle 27 11-24-2009 03:53 AM
Door latch / lock / alarm system IceDog Technical Modifications 1 09-16-2009 10:01 AM
Door lock sensor XCman Questions, Issues, Concerns, or Problems with the New Beetle 3 03-13-2007 08:14 PM
Have to double lock to lock doors. Help whyjay91 Questions, Issues, Concerns, or Problems with the New Beetle 7 06-27-2006 07:13 PM
replacing seatbelt latch sensor ttupper Questions, Issues, Concerns, or Problems with the New Beetle 5 12-27-2005 02:57 AM
