center console lock - NewBeetle.org Forums
Old 03-22-2011, 08:55 PM
Denver, CO,
Car: 2004 NBC 1.8T Sport
Default center console lock
2004 NBC the center console lock tumbler turns with the key but it doesn't unlock. Anyone know a way into the compartment?
Old 03-22-2011, 09:07 PM
MyOtherRidesAVette's Avatar
Exclamation
Is it just the "cylinder" turning, or is the whole housing. Sounds as if the housing itself is turning, in which case you need to try and hold it while you turn the key. If this is the proble, once you open the lid you can simply lift out the storage pocket (spread your fingers inside it and lift, or lift out the CD Changer. Once you have access, you will have access to the back side and should be able to tighten the cylinder housing in the console body.
I don't have the lock in my '05. It was deleted after '04, but Tico4Life has the '04 and might be able to add some information.
MORAV
In der Automobil-Scheune
Old 03-22-2011, 09:43 PM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
The whole panel on the passenger side comes out and you can access the lock (and anything else) from there. To remove the side panel move the pass seat to its most forward position and tilt the backrest forward.
Refer to the pics from there to remove panel (21) and access the lock.
—Ambrose Redmoon
Old 03-23-2011, 11:16 AM
ubugnme04's Avatar
Proctor, VT, USA
Car: 2004 NB Convertible GLS
I had an issue with the lock on my center console. The tumbler went. I had VW fix it as I was under warranty at the time and had my 6 disc changer in there.
Rest In Peace Papa - June 23, 1941-October 20, 2008.
Rest In Peace Daddy Pete - October 1, 1920-November 12, 2008
Can a 05 center console fit in a 99 bug?? petes Questions, Issues, Concerns, or Problems with the New Beetle 13 05-06-2009 07:08 PM
Center Console Scotch Styling Modifications 2 06-06-2007 07:55 PM
WTB- Center Console- 04 up locosol96 Market Place Archives 0 10-28-2006 03:24 PM
center console detailstation Technical Modifications 4 07-01-2006 03:17 AM
Center Console HELP! sntaylor Styling Modifications 12 04-26-2006 05:21 PM
