ESP sensor location - NewBeetle.org Forums
Old 06-01-2011, 08:16 PM
Bangor, Ireland
Car: 2003 NBC, 1969 OBC
Default ESP sensor location
Hi, first post, although I've dipped into your forum a few times for help. I've a 20003 RHD NBC and have had numerous electrical problems mostly window and doors. This time I have another problem. Along side the usual door motor fault codes I now have:
00493 ESP sensor unit G419 faulty, and the fault light is on in the dash.
The sensor unit is very expensive and I want to check the wiring connections etc before I decide if I'm going to replace.
But I don't have a clue where the sensor unit is located and can't find it via any searches
hope someone can help
Old 06-01-2011, 11:28 PM
Bangor, Ireland
I realise that most of you guys drive LHD and prob don't know the location on a RHD model but if you tell me where it is on a LHD i can work it out. Generally the engine/body stuff isn't moved but dash/steering and associated electrics are
Old 06-07-2011, 09:26 PM
Knoxville, TN,
The G419 is located next to the steering column. Now on the LHD vehicles, it is located just to the right of the column, I would guess it would be the same on the RHD as well. It is about 2.5" wide box with rounded corners.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
coolant temp sensor location jdubvdub 1.8 Liter Turbo 1 04-09-2011 05:35 PM
Location of #2 knock sensor?? TheBeetleLover Questions, Issues, Concerns, or Problems with the New Beetle 10 11-08-2010 03:25 AM
Coolant temp sensor location FD5150 New Member Forum 1 05-24-2010 12:53 AM
PO0322 Crank Sensor Location? pete1325 2.0 Liter Gas 1 08-22-2009 10:57 PM
Oil Pan Location & With Or Without Sensor? amiga 2.0 Liter Gas 3 10-21-2008 03:02 PM
