07 nbc filter - NewBeetle.org Forums
Old 08-07-2011, 11:21 AM
ricaroo's Avatar
Rick
NH, USA
Car: 2007 NB Convertable triple Beige
Default 07 nbc filter
I have a 2007 nbc and went to change the pollen filter and I found that my car did not come with one from the factory?
is this common? when I called the dealer they told me my car does't have one because it is a vert.
anybody else come across this with their nbc?
Everything works out in the end, if it hasn't worked out,then it's not the end.
Old 08-07-2011, 11:49 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
My 09 NBC did not have one either. I added one which is a simple task. Search the org for posts. You only need two parts from a donor car or buy new. Remove the screen filter and install the new filter housing using same two nuts, put the real filter in the filter frame and your done.
Tom
Old 08-08-2011, 08:30 PM
Knoxville, TN,
It can be normal, VW started deleting the pollen filters a while back in some Beetles.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 08-08-2011, 08:40 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Yes. If you look at your car very closely and compare it to a 03 (first year for NBC) you will find a lot of little things gone: gas cap holder clip, drivers side under dash panel, door warning lights, pollen filter, under dash red light (ash tray light) above cup holder, passenger's door security light, light in 12V sockets, trunk 12V accessory socket and more . . .
Old 08-13-2011, 05:01 AM
hadda61beetle's Avatar
Greenleaf, WI, USA
Car: '07 Laser Blue NBC; '05 Passat Wagon TDI; '99 Ford F-150 4x4; '23 Ford T-Bucket
I read somewhere recently...oh yeah, it was in my owner's manual that the only bugs that have the pollen filters are the Canadian bugs. Look at the maintenance section in the owner's manual.
Old 08-13-2011, 04:17 PM
MyOtherRidesAVette's Avatar
Aw c'mon, you drive a Vert and your worried about having a dust and pollen filter? The latest OM I have is an '08 and the only reference made to a dust and pollen filter is in the maintenance section, indicating the need to change it, "WHERE APPLICABLE". IMHO, these things are quite stupid anyway, just something else to maintain, and from what I have seen (Bentley) a PITA to get to and change. Also a source, I would guess, in areas of high humidity, for mold spores to flourish. But to answer your question, I don't believe my '05 NBC has one either, if I find it does, it'll be deleted.
MORAV
In der Automobil-Scheune
Old 08-14-2011, 04:53 AM
JonK's Avatar
PA, USA
Car: (Rosebug) 2008 Salsa Red with Black roof, mirrors & spoiler, NB 2.5 S Coupe, 70K
My 2008 hard top, dosn't have a pollen filter!!!
JonK
Rosebug will turn 5, July 5th, 2012
Old 08-14-2011, 03:49 PM
Question
JonK
This would be a guess, but since we have somewhat established the earlier deletion of this feature in the NBC, and since the OM states "where applicable", it is entirely possible that the elimination of this was planned for '08 and became a "running change" when the inventory of this part hit "0". Thus the note "where applicable".
M.
Old 08-14-2011, 04:47 PM
lil.smartie's Avatar
Henderson, NV and Wells UK, NV, USA
Car: 2000 1.8t 5mt GLX Hatch US and 2002 1.8t hatch UK
Not too bad to change, we did Cookies and it looked like it was the original from 02 in there! Leaves & everything!
Kate
Old 08-14-2011, 05:51 PM
I think its an '06+ change with the no cabin filter thing. It wasn't until people with the '06 cars started posting that I heard about no cabin filter.
Old 04-23-2012, 04:10 PM
My 07 vert does not have a pollen filter either.
Old 04-23-2012, 04:40 PM
IndyTom's Avatar
Indianapolis, IN, USA
True, I don't think any 2006+ models have them. But you could still install one if you so desire. It is a bit of a pain to get to the place where the pollen filters were originally but it can be done with a little patience and about 45 minutes of work.
Old 05-01-2012, 01:35 AM
Default oil fillet canister
Any one no the size of the socket to remove canister on a 2008truck beetle ..
Old 05-01-2012, 11:14 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Default Oil Change How To
DIY: Oil Change for 2.5L
air filter?? just.smile 1.9 Liter TDI 5 06-23-2010 01:06 AM
Pollen Filter Not Cabin Filter BWYMAN2112 Questions, Issues, Concerns, or Problems with the New Beetle 22 04-02-2010 10:46 AM
Can't get oil filter off? PinkBug4289 Technical Modifications 8 11-02-2009 05:26 AM
Oil Filter RedLoveBug06 2.5 Liter Gas 1 09-06-2006 04:28 AM
