2005 New Beetle wont go down. Tried relay reset. - NewBeetle.org Forums
Old 10-11-2011, 12:25 AM
Default 2005 New Beetle wont go down. Tried relay reset.
I recently had my battery replaced and now my top won't go down. I followed the instructions here on the forum for resetting the switch (using the master window switch, etc. to roll up/down windows). The problem is the MASTER window switch does not work!!! all other window switches work. The master doesn't so I can't reset the top. What do I do??
Old 10-11-2011, 02:07 AM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Hmmm... That's weird. Maybe the reset needs a reset :-(
SoCalnewbeetleclub
Old 10-11-2011, 04:32 AM
Knoxville, TN,
The master switch may just be screwed for some reason. But you can still relearn the windows with the other switches. Just roll the windows up, then pull up 3 or 4 times on each switch for a couple of seconds. Then see if the top works.
If not, would be nice to get some Measuring Block data from the Roof Electronics. If you have a dealer level scan tool, then you can view all kinds of switch conditions and have a much better idea of what is going on. Right now, you are sort of flying blind.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
2005 New Bettle Convertible Top wont go down Germandude New Beetle Convertible 13 09-11-2011 05:45 PM
2005 Beetle top trips breaker and wont open Cue New Beetle Convertible 16 02-15-2011 02:14 AM
2005 Beetle hatchback relay map needed hjbreese 2.0 Liter Gas 9 01-01-2011 02:22 AM
wont start AGAIN!! 109 relay?? CrabbyPatty 1.9 Liter TDI 4 04-28-2010 05:22 PM
fuel pump relay wont stay on ....??? beat down beetle 1.8 Liter Turbo 2 02-22-2010 10:55 AM
