Since neither the remote, nor the door switch are working, you can probably rule out those two items. The [V53] Rear Lid Central Locking System Motor is directly wired to and controlled by the [J393] Comfort System Comfort Control Module. There are two intermediate connectors between the two.
You need to check for power at the motor (when the release is activated) to determine if it is the motor itself, and then work backwards, checking for power at all connections. If you have power to the motor, you might then check for continuity to ground of the ground wire. If it's not a problem with the motor, or the wiring to the motor, I suggest you then have the CCM checked with VAG equipment by someone who has both the equipment and the knowledge to use it properly.
The most common problem I have read is a broken wire at the motor.
Below are some diagrams to possibly help you track down the problem.
MORAV
In der Automobil-Scheune
