Purger valve problem - NewBeetle.org Forums
Old 01-11-2012, 04:20 PM
Default Purger valve problem
Why would the purger valve crap out. 2008 New Beetle. If the gas cap was not screwed on tight, would that cause the indicator light to go on?
Old 01-11-2012, 04:38 PM
I assume that means you have a CEL? What is the code? And yes, a gas cap not screwed on tight enough can trigger a CEL.
2.5L PCV valve, valve cover replacement questions PTL5spd 2.5 Liter Gas 2 09-03-2011 11:27 PM
Evap Purge Valve/N80 Valve BUGSTUFF 2.0 Liter Gas 6 03-17-2011 12:51 AM
diverter valve/ blow off valve silver01beetle Miscellaneous Hoo-Ha Archive 3 06-20-2006 05:29 AM
Exhaust Valve Problem . . . Mr Natural 1.8 Liter Turbo 2 02-19-2006 04:09 AM
combie valve & N112 valve (vacuum lines)??? marisagi 1.8 Liter Turbo 1 02-09-2006 11:53 AM
