2005 super beetle conv. low beam problem - NewBeetle.org Forums
Old 01-24-2012, 12:16 AM
Default 2005 super beetle conv. low beam problem
Original problem was intermitten low beam on passenger headlight. A very gentle tap on light or closing the door would turn light on. Removed light and checked for loose or bad connections and found none. Removed bulb, it has continuity and lit up with 12 volts applied. Bright beam works. Cleaned where bulb frame touches holder. All wires thru socket check good. Replaced in fender and now low beam doesn't work at all. Is green wire ground and where does it go? Thanks for any suggestions. Have knowledge of electricity but not car wiring. Bill
Old 01-24-2012, 02:21 PM
Knoxville, TN,
Brown is ground. The green is for the low beam and goes to fuse S20 (10A fuse). The white wire is for high beam.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 01-24-2012, 10:04 PM
Default reply to pencilneck
Thanks for the reply. Fuse # 20 was blown but replacing didn't fix problem. I guess I accidently blew it while working on light. Tomorrow I will check to see if I am getting voltage. I read on forum that someone found a broken wire even tho it checked good with meter. I am getting tired of removing and replacing light. Thanks for the wire color info. In appliance and house wiring, green is usually ground. Is there any place I could get a written, rather than a symbol, discription of what each fuse protects? Thanks again for the information, any other suggestions appreciated. Bill
2005 Conv. Do it yourself Oil Change??? creese 2.0 Liter Gas 5 04-09-2011 02:01 AM
New Beetle Conv. owner!! keadam0 New Member Forum 4 01-04-2011 02:35 AM
both low beam headlights went out, how do i replace them...2005 beetle 4teri New Member Forum 1 08-15-2010 03:13 AM
Problem with tail lite on 2005 Beetle flachusnret Questions, Issues, Concerns, or Problems with the New Beetle 3 09-26-2009 01:58 PM
2005 VW Beetle Conv. Light Issues church New Beetle Convertible 1 01-21-2009 01:58 PM
