Convertible top rattles - NewBeetle.org Forums
Old 02-22-2006, 01:19 PM
Car: '05 NBC Turbo, '06 GLI
Default Convertible top rattles
My wife's 2005 NBC has had a rattling issue since new... It seems to be somewhere (or all along!) where the top meets the windshield frame. It occurs most when the weather is cold.
At each service, we have asked the technician to take a look at it. Each time it comes back with "operation as normal." However, the last time, the technician "lubricated top seal, rattle gone."
Yes, the rattle was gone! We drove in blissful silence for about a week... Until the rattle came back
I was surfing another forum, and a member suggested wiping 303 Protectant on the seal... He said that would take care of the rattle, and last longer than whatever the dealer used. I did a search here, and found some to suggest WD40 for the same purpose.
First question: is this an issue with all NBC's? In other words... Should I keep pestering the dealer?
Second question: for those that have this annoying rattle, how do you solve it, and how long does the solution seem to last?
Old 02-22-2006, 07:27 PM
Silverthang's Avatar
England, United Kingdom
Car: 2004 Cabriolet
Take a look at this thread from the UK site. There are some photo's that may interest you?
http://www.newbeetle.org.uk/justbugg...opic.php?t=826
Old 02-28-2006, 02:31 PM
So I take it from the non-response of the group that this is not a common, normal occurance on the NBC? If this is the case, I'll press the dealer for a solution! We have a 20k scheduled this weekend, so this would be a good time
Old 02-28-2006, 05:32 PM
schen72's Avatar
San Jose, CA, USA
Car: 2005 NBC GLS 1.8T
No, it is not normal. We had the exact same problem with our 2005 NBC. The first time we complained about a "rattling" sound near the latch, they applied some special "tape". I talked to the service technician directly, and he told me that the real solution is to replace the latch with a slightly thicker one, so it wouldn't rattle around. But VWoA will not allow dealers to install the new latch without first trying the tape.
I believe it's a ploy by VWoA to first try the half-assed solution (tape) in the hopes a certain percentage of people won't complain about it anymore.
So I did the tape, and in about 2 weeks, as I predicted, the rattle came back. Then I went back and said I'd like the new latch. The problem is fixed and it's been about 3 months.
Just another example of how VWoA tries to cover up a poorly designed product. I so wish the NBC was better built... but don't get me started...
Old 02-28-2006, 05:37 PM
This is the only complaint I have about our NBC... Everything else has been stellar.
Thanks for the info. I will press the dealer for a solution. I think asking a tech to come along for a ride is all I need.. It's not a quiet rattle
Old 02-28-2006, 08:51 PM
TampaDub's Avatar
tampa, FL, USA
Car: 2004 NBC named "Powder"
I just had my vert top side seaams replaced. Now mine too rattles. But I have noticed that the panel that goes back when i put it down (the panel the D latch that you turn is on) it is loose from the top in that corner like they broke a clip or something when they put it back togeether. if that isn;t the rattle for me I will try the tape but now I have to spend the day getting the clip fixed!!!!
Old 03-01-2006, 04:21 PM
My 2006 new convertible still rattles, and I have yet to try the WD40 as suggested. I have my first 5,000 mile oil change in a couple of weeks. I plan on complaining for the 4th time at that service, and I will also ask if the WD40 is okay to use. I'm concerned that the tight seal the car has may be compromised if I do. My owner's manual said to expect noise from convertibles.
Good luck. Hopefully, we can find a way to quiet things down.
Old 03-01-2006, 04:22 PM
P.S. My rattles are down each side and near the door latches.
Old 03-01-2006, 07:00 PM
I will keep everyone posted on the solution (if one is found). Our service was moved to next weekend. If VW doesn't have a good solution, I'm going to buy some 303... It's driving my wife a little batty
As I said, we love our car otherwise. Although maybe a little more power would be nice
Old 03-01-2006, 07:41 PM
CGK's Avatar
Beetleman
Salisbury, NC, USA
Folks,
I have had the rattle or what sounds like two pieces of metal rubbing against each other, as well. Mostly when going over rough road surfaces, bumps or railroad tracks and primarily in the cold.
The solution I have used was to remove the plastic panel that conceals the top latch mechanisms. To do this,release the top and raise it half way; carefully pry the front edge with a plastic or wooden flat tool (prevents scratches). The front edge is held in with metal clips all along the front edge. Then there are four plastic "tree" clips that hold the center of the panel in. Pry the panel carefully down to release these from the top holes. Once disconnected, pull down, twist and hold the lock handle, turn the panel at a right angle to pull in over the handle and set the panel aside.
Now, you will see all the handle mechanics and rods and latches that lock the roof down. Get some Genie garage door lubricant. It's actually "Lubriplate" white grease. It's specially designed to withstand heat and cold without running or solidifying. Using it sparingly, apply to all the moving parts you can see by moving the handles and seeing what rotates or moves. You'll even see some of this grease on the return spring for the handle. Make sure to lube everything including the guide pins at each end of the roof, the latch hook surface that grabs the header when closed, the header bushings that meet the latch hooks and when all done, replace the panel in reverse order.
Lastly, as others have already mentioned, use some 303 protectant and coat the surface of the header seal on the top edge of the windshield that seals the top.
That should do it. I believe the dry surfaces of metal, plastic and fabric combine to create the moans, groans, squeeks and rattles in top.
This has worked for me and I haven't had a sound from the top for a year now.
Hope this helps guys.
Old 03-01-2006, 08:13 PM
schen72's Avatar
San Jose, CA, USA
You simply need to ask for the redesigned "hook" that latches the top shut. VWoA redesigned the hook to be slightly fatter all around, so it makes a tight fit, thus no rattling.
Old 03-02-2006, 02:29 PM
The redesigned hook sounds like exactly what we need. Does anyone have the part number in case my dealership "doesn't know" about it?
Old 03-03-2006, 06:47 PM
gunthermoose's Avatar
"Here is what my repair invoice lists regarding the convertible lock mechanism:
61445500 REPLACE LOCK
1688 WV03
01320024 TECHNICAL DIAGNOSIS
1298 WV03
1 1YO-871-383-B-3PT LOCK
2 1CO-868-243 CLIP
FC: 614415BFA2
PART#: 1YO-871-383-B-3PT
COUNT:
CLAIM TYPE: W2
AUTH CODE:
2005 Galactic Blue Beetle Convertible 1.8 Turbo
Old 03-09-2006, 03:50 PM
BINGO! Just got back from our 20k... My tech knew nothing about the new latch mechanism, but rang up Tech Line anyway... There is indeed a new mechanism. A TSB is forthcoming in the "coming month" according to Tech Line. The parts are ordered and we're having the fix done next Saturday (18th).
Thanks to schen72 and gunthermoose!
Old 03-09-2006, 09:52 PM
schen72's Avatar
San Jose, CA, USA
Glad it worked out. The good news is my new latch has been rattle-free ever since it was installed -- at least 4 months ago.
Old 03-10-2006, 01:03 PM
Well, it hasn't worked out quite yet, I'll reserve a victory lap for the hopefully quiet drive after the latches are replaced on 3/18
This is good news, indeed. It's essentially the only thing we didn't love about the NBC.
Now we just need to chip it
Old 03-27-2006, 11:24 PM
Default rattle is driving me crazy!!!!
Yes, I have the exact same problem that you have. I have 2005 bug and the problem started 2-3 months after I purchased it new. I am now in my 16th month of the ownership of the car and the problem is only getting worse. I have had the car in the dealership six times and it is now heading back for its 7th visit. I keep getting the run around from the dealer and they say its "body flexing".....yeah right. I am so frustrated!!! Did you ever get any resolution on your problem? I also have a paint issue with the car, and the canopy top keeps coming loose from the interior rear window.
Old 03-27-2006, 11:28 PM
Default frustrated
Old 03-28-2006, 12:16 AM
schen72's Avatar
San Jose, CA, USA
The new latch solution has worked for me. It is a new part from VW, and I highly suggest you get it from the dealer. You may have to pester them for it though, as many dealers are ignorant of it.
As for the headliner coming loose from the rear window, it hasn't happened to me, but I've read of others having the same problem, and having it fixed under warranty.
Yes, the Beetle is a very fragile car, and IMHO, a crappily constructed car. In many ways, it is overengineered and prone to mechanical failure. But I suppose that is the price one pays for German engineering. I don't think my wallet or stomach can handle another German car after this. We're going back to Acura for the next car!
Old 03-29-2006, 02:39 AM
Default German engineering...puh-lease
Actually our German cars are made in Mexico and Brazil. If I had only known I was buying a German "enchilada or empanada", I might have thought again. I just want to get it noise free so I can sell it. I will take them the info on the latch.
Door rattles The1 New Beetle Convertible 12 04-06-2007 02:38 AM
Help-My 06 New Convertible Rattles Izzie New Beetle Convertible 1 12-02-2005 12:05 AM
Convertible Care jdl New Beetle Convertible 10 11-21-2005 07:25 PM
Convertible boot Estrella74 New Beetle Convertible 1 11-13-2005 01:42 PM
