Odor Removal - NewBeetle.org Forums
Old 06-02-2007, 09:53 PM
worbc's Avatar
Tustin, CA, USA
Default Odor Removal
For those of us who have had the bad smell coming from the Air Conditioner system, and have tried everything to get rid of it, I found something that works great. It’s called FJC Air Conditioning Evaporator Odor Control, 6 OZ. AEROSOL (5909). Do a search for FJC 5909 and you'll find it, its less than $10 a can. It works easy and fast just follow the instructions and within minutes the smell is one.
However, also make sure the evaporator flap is not stuck or the smell will return as the water remains trapped.
--terry
-_-_-_-_-_-_-_-_-_-_-_-_
Terry (WORBC) Rector
1999.5 NB with following modifications, VR6 Clutch & Lightweight Flywheel, CARACTERE body kit, Special modified exhaust with Magnaflow Muffler, Three Gauge Pod with Boost, Oil & Water temp gauges, Rocketchip Stage III, Sprints 520s, ProSound System, ProVent CCV
"You can't build a reputation on what you're going to do." Henry Ford
Old 06-03-2007, 07:25 AM
Evanrude's Avatar
~Feel the Sting~
Longview, WA, USA
where is the evaporater flap and how do you check it ?
Old 06-15-2007, 02:32 PM
dalethompson's Avatar
Did you add it after you changed your AC/Pollen filter? I have the musty smell in my car right now but I haven't cleaned out or changed my filter yet. Thought I would do it this weekend and see if I still get the smell.
"The internet? Is that thing still around???"
Old 06-15-2007, 02:41 PM
worbc's Avatar
Tustin, CA, USA
Search for the evaporator flap and you will find a “How too” on this forum that explains how to check it, but its located on the silver firewall, just about center of (behind) the motor, it looks like a tear drop and needs to be carefully lifted where you will see a rubble flap. I pulled the complete flap carefully out and cleaned it.
Old 06-15-2007, 02:42 PM
worbc's Avatar
Tustin, CA, USA
I had changed the filter earlier, and other things trying to kill the smell, but nothing worked until I used this material.
Old 06-15-2007, 08:11 PM
XSuMZX's Avatar
TACO!
Savannah, GA, USA
Car: Black 2K2 1.8T
If your trunk leaks you'll get a pretty rank smell through your a/c too.
[[[ seeuro ]]]
Old 06-17-2007, 02:46 AM
AirbusMech's Avatar
Das Kriegswagen
Rio Rancho, NM, USA
Car: 06 Beetle TDI GLS Package1, Salsa Red, Leather XM Radio Monsoon Sound Sytem, Panzer Plate
i drove around a few day with the windows down and the a/c off fan on high and recirc in recirc mode the stench dransticaly diminished.
Dent removal thunder bug Miscellaneous Hoo-Ha Archive 2 05-13-2007 04:10 AM
Pulley Removal 2000GLX 1.8 Liter Turbo 1 10-13-2006 06:06 PM
Alternator Removal Legendlime 1.9 Liter TDI 3 10-06-2006 12:49 PM
Removal Tools MOONDOG316 Car Audio 1 01-10-2006 10:53 PM
