Soft touch sucks. - NewBeetle.org Forums
Old 09-12-2009, 02:07 AM
Terre Haute, IN, USA
Car: 1999 Beetle TDI, 1990 Audi CQ, 2002 Audi A4 6mtq, 2000 VW Pointer
Default Soft touch sucks.
I've started removing mine, so far so good. I got a product called "Awesome" from dollar general and a green scrubby pad. If you don't know what soft touch is, it's that crap in your interior that's peeling.
If your's isn't peeling, consider yourself blessed.
This chemical is rather potent, i'm rather high and if i breath in around it, it's similar to horse radish. This takes a long, long time to do, if patience isn't your virtue, i suggest you don't do it. Do not try anything other than this product as it will eat the plastic. Ask me how i know.
Old 09-12-2009, 02:10 AM
topless kitty's Avatar
Not low enough
fairfield, CT,
Car: 2003 GLS vert
people have had luck with nail polish remover too. still stinks, but probably more bearable.
i'm pretty lucky, the only part of mine that is peeling is on the bottom edge of the trim around the speedometer. it's basically nothing.
Old 09-12-2009, 03:44 AM
Got it done, and the pad scratched the plastic, i used rubbing compound and still couldn't get the scratches out. I said screw it and used some black paint i had laying around, unfortunately rattle can because i had no reducer or harder for the car paint i have. Went to Wal-Mart and found some new type of clear coat called "Glaze". It's meant for clay pottery that's porous and fills in the imperfections. It's cloudy, but as it's drying, it's becoming amazing looking. Used half a can on the center console, this stuff is sticky like car paint and goes on thick (used only 3 coats).
"Take this, it will help you along you way".
Old 09-13-2009, 02:11 AM
Hmm, this turned out quite sexy, almost like actual automotive paint.
Old 09-13-2009, 02:16 AM
Not low enough
fairfield, CT,
Car: 2003 GLS vert
not bad my friend. installed pics?
Old 09-13-2009, 04:25 AM
Erm...
I should clean my garage so i can actually pull my car in it where there's some light.
Old 09-13-2009, 12:28 PM
Not low enough
fairfield, CT,
Car: 2003 GLS vert
haha. well, looks good so far you can get away with glossy black because your car is black, so it's like "colormatched" basically.
Old 09-13-2009, 02:50 PM
AbuNigel's Avatar
buggin
Bridgeport, CT, USA
Car: 2000 2.0L Red New Beetle GL
wow that's pretty cool. So you basically just clear coated the bare plastic and got a glossy painted effect?
My 2.0: 'Lil Red'
Old 09-13-2009, 03:31 PM
You actually could if you get the plastic looking good enough, but i laid a semi gloss base coat to hide some things.
Old 09-13-2009, 10:19 PM
Oldbugman's Avatar
Jacksonville, FL, USA
Car: 2000 GLX 1.8T 5 SP
Looks pretty sweet, think I'm gonna go with a satin finish versus gloss think the gloss will give off to much glare at night but nevertheless that looks sweet.
Old 09-14-2009, 02:04 AM
Doesn't glare, i thought the same, i wanted satin, but it didn't look near as good to me.
Old 09-14-2009, 03:25 AM
Not low enough
fairfield, CT,
Car: 2003 GLS vert
planning on doing any other pieces?
Old 09-14-2009, 03:37 AM
Probably the door handle things as well. Other than that, i'm not motivated to do the rest, way too much work.
Old 09-14-2009, 03:42 AM
Not low enough
fairfield, CT,
Car: 2003 GLS vert
i think you mean way too many fumes
Soft Clutch northernlad 2.0 Liter Gas 4 10-21-2007 04:47 AM
Soft Top cleaning bug746899 New Beetle Detailing/Cleaning 0 07-01-2006 02:50 PM
How do I clean my soft top? cutelittleblondegirl New Beetle Detailing/Cleaning 1 06-08-2006 01:48 AM
