Gluing Headlight Lens Back On - NewBeetle.org Forums
Old 01-05-2010, 01:25 AM
virgo80's Avatar
Los Angeles, CA, USA
Car: 2004 GLS Galactic Blue
Default Gluing Headlight Lens Back On
The glue on my passenger headlight gave out and *dink* fell off during a road trip after I had parked. What kind of glue/adhesive can I use to securely glue the plastic lens cover back on? There isn't enough of it left on the underside to reattach.
Old 01-05-2010, 11:28 AM
CGK's Avatar
Beetleman
Salisbury, NC, USA
I had the same thing happen to one on my wife's NB.
The first thing you need to do is dig out all of the old sticky gunk left on the lens and on the headlight itself.
Then get a tube of gray colored silicone adhesive caulking that you can apply with a caulking gun.
Lay in a good thick even bead all around the light fixture. Once you dig out the old gunk you'll see the groove that needs to be filled.
Then, apply the lens back onto the headlight very carefully and put several spring clamps around the lens to keep pressure on it while the caulk cures. Leave it at least overnight until it completely cures and you'll have a tight waterproof seal once again.
Just be sure to place the lens on real well in one shot. Otherwise, if you pull it out again, you'll end up with a gooie mess and you'll have to start over again and it won't be easy.
Good luck
Old 01-06-2010, 04:15 AM
virgo80's Avatar
Awesome! Thanks so much for the reply. Is there a recommended brand of silicone for that or will any do?
Old 01-06-2010, 11:16 AM
CGK's Avatar
Beetleman
Salisbury, NC, USA
GE silicone caulk is the one I found in a gray color that is closest to the OEM adhesive. But, if you can't find that you can look for DAP or Red Devil.
headlight lens restoration kit? Zippy98 New Beetle Detailing/Cleaning 21 09-20-2010 12:42 PM
headlight lens Q ??? RUBZERK Styling Modifications 1 10-19-2009 07:05 PM
WTB: Headlight Lens watcurb@aol.com Parts and Accessories 2 01-06-2009 02:00 PM
headlight lens pulling off laylow Questions, Issues, Concerns, or Problems with the New Beetle 3 06-21-2006 03:56 PM
WTB: Headlight lens huskyfan_7 Market Place Archives 0 06-03-2006 08:41 AM
