Re-Spraying a Bug Question.. - NewBeetle.org Forums
Old 05-22-2011, 07:46 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Question Re-Spraying a Bug Question..
Why does everyone keep saying, you need to take off the fenders, and other parts etc. In order to get a good respray ?
The Pink Bug that has been sprayed on here, looks Cool and they left the fenders etc on
Just always wondered why people have said to take off and spray seperately
Old 05-22-2011, 08:22 PM
dmbluebeetle's Avatar
Blue Hunter
Riverside, OH, USA
Car: Blue '04 N. B. Turbo GLS
I would guess to get good coverage in the seams where the fenders and body meet.
Old 05-22-2011, 09:02 PM
MyOtherRidesAVette's Avatar
Thumbs up
Actually you don't have to separate any body panels or remove anything, i.e. lights, trim, badges, etc. Just all depends on how quality of a job you want. Part of the difference between a $1200 paint job and a $6000 paint job. And "going pink" thread you are following is a complete color change, which requires even more painting of areas which generally don't even get painted when you simply repaint or "refresh" an existing color. Also anytime you mask as opposed to remove, you run the risk of a paint "edge" which is much more susceptible to peeling. I'm sure you red threads where someone is having trouble with clearcoat peeling.
Then when it comes to painting the bumpers, to do these properly requires an additive to give the paint the ability to flex and not crack. Another paint edge susceptible to peeling. Of course most novices, or shops doing cheap jobs, simply paint over everything with the same coats of paint.
MORAV
In der Automobil-Scheune
Old 05-22-2011, 09:06 PM
Blugg's Avatar
Originally Posted by MyOtherRidesAVette View Post
Actually you don't have to separate any body panels or remove anything, i.e. lights, trim, badges, etc. Just all depends on how quality of a job you want. Part of the difference between a $1200 paint job and a $6000 paint job. And "going pink" thread you are following is a complete color change,which requires even more painting of areas which generally don't even get painted when you simply repaint or "refresh" an existing color. Also anytime you mask as opposed to remove, you run the risk of a paint "edge" which is much more susceptible to peeling. I'm sure you red threads where someone is having trouble with clearcoat peeling.
MORAV
Thanks for that reply
Everything i wanted to know and more
Have a Nice Day
Oil leak spraying from top!! low_k3y 2.0 Liter Gas 4 03-24-2011 03:37 PM
pcv valve question and oil question a_magoo 1.8 Liter Turbo 3 10-07-2006 01:31 AM
p 0411 code question and coolant leak question.... bobbittle 1.8 Liter Turbo 5 06-12-2006 02:47 PM
