laundry detergent?? - NewBeetle.org Forums
Old 12-13-2011, 03:14 PM
lilu05's Avatar
Providence, RI, RI, USA
Car: 2003 VW Beetle 2.0L GL
Default laundry detergent??
Okay, so I was transporting my laundry to the laundry mat and some of the laundry detergent leaked onto the backseat! It's a spot about the size of a half dollar. I tried to soak it up with a wet cloth but that didn't seem to work. Anybody have any ideas on this?
Old 12-13-2011, 06:09 PM
Bratgirl's Avatar
Powered By Pixie Dust
Riverton, UT, USA
Car: 2002 Yellow GLS
This happened to me, but in the trunk of another car I used to own. I don't know how well this might work for you with the "padding" the seat has, because mine was just in the carpet in the trunk.
Anyway, I used a Shop Vac and a spray bottle of water set to a stream, not the mist setting. Spray the spot with water until it is wet, (trying to keep the wet area localized so it doesn't spread everywhere), vacuum, and repeat until no more soap or bubbles.
Hope this helps.
Barb
Live a Life of Serenity, Not a Life of Regret.
Current NB 2002 GLS Double Yellow "Pixie"
Previous NB 2000 GLX Black "Little Ed"
"Other" Road Trippin' Ride
2010 Dodge Challenger Bright White "Baby"
Old 12-13-2011, 07:09 PM
Yah, just wetting and sucking up until the soap is extracted should be fine. A carpet cleaner might be a better choice than a shop vac, but shop vac will work.
About the only issue you might find after that is having one spot really really clean.
Old 12-14-2011, 01:31 AM
lilu05's Avatar
Thanks guys! I never thought to suck it up with the shop vac. I'll definately be trying this this weekend
Turbo S Laundry List Palmettoguy Technical Modifications 73 10-11-2011 03:36 AM
Laundry: How do I get the smell of Gasoline out of clothing? CrazyJames Miscellaneous Hoo-Ha Archive 21 11-25-2005 06:32 PM
