Turning off the Alarm - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > Community > The New Beetle Experience
The New Beetle Experience The place to tell us all about your experiences as a New Beetle driver.
Old 05-12-2006, 12:35 AM
Twiddlebug's Avatar
Beacon, NY, USA
Car: 2000 Batic Blue GLS
Question Turning off the Alarm
Hi!
I need to learn how to shut off Twiddle's alarm. We will be going on the Auto Train and that's a requirement!
I also need to leave the key in the igniton for the operators to move her around - the interior lights will eventually shut off, right? I know when I use her, they stay on until I take the key out of the ignition.
I realize, of course, I can take the key out & put it back in, but I'm just asking for help to make sure I don't wind up with a dead battery when I get off the train. (even though it's a super duper gel battery...I don't want to take any chances....)
Thanks!
Erin
Old 05-12-2006, 12:52 AM
Steinola's Avatar
Portland, OR, USA
If you have a stock U.S.-spec NB, there is no "alarm", persay. Not in the traditional sense that the Auto Train is probably leary of (ie - one with motion and impact sensors). It's simply central locking, with an alarm if the door is opened while it's locked.
Simply don't lock the door. Problem solved. And if they take the key and lock the door, they'll have to use the key to unlock it... which will also deactivate the alarm. Unless someone is breaking into the car, it should never go off. I don't know a way to completely disable even the door ajar alarm. If they insist on it, just unplug the horn.
As for the interior light... yes, it should eventually go out, even with the key in the ignition. But, heck, there's a simple way to be sure... just stick the key in the ignition while it's sitting in your driveway... and see if the light goes out. If not, then simply turn it off manually (for coupes, that means rocking the light fixture to one of the other positions so that the lights don't come on when the door is open... for 'verts, that just means flipping the light switch on the rearview mirror).
Traction Control Light not turning off dvious Questions, Issues, Concerns, or Problems with the New Beetle 3 04-21-2006 08:03 PM
Turning lights on mirrors crazi_daisy Styling Modifications 1 02-14-2006 01:45 PM
Beetle turning into an airplane?? Vayleen 2.0 Liter Gas 8 11-26-2005 05:56 PM
Transaxle noise when turning left fatbob 2.0 Liter Gas 1 11-24-2005 10:40 AM
