Leaking Coolant, Help!!! - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > NewBeetle.org > New Member Forum
New Member Forum This forum is the welcoming room for new members of NewBeetle.org. Please stop by and introduce yourself or ask questions on the use of the forums and this website.
Old 07-27-2006, 01:15 AM
Question Leaking Coolant, Help!!!
My beloved 2001 Isotope Green New Beetle is leaking coolant!!
Coolant level drops from the upper level mark on the reservoir to the lower level mark within a week.
Took it to the VW dealer here in Silicon Valley, and they said that the auxillary / secondary water pump is bad. Repiar cost is $440 parts and labor.
Is there such a thing as an auxillary water pump in the New Beetle? I have only heard of THE water pump and timing belt.
Also is the repair cost reasonable?
Please help!!
Thanks!
Old 07-27-2006, 07:13 PM
ghostRder1's Avatar
GA,
Car: 2006 Convertible
Welcome to the org! Sorry about your trouble . Have you had a VW dealer check out the problem since posting?
Old 07-27-2006, 08:25 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Ok, that's a new one... did you ask your VW dealer where this secondary water pump is located?
Old 07-27-2006, 08:48 PM
jimRegistered Member jim is offline
Old Dog
Moore, OK, USA
Car: 2003 GLS
Could that be the electric pump that runs after the engine is shut off to cool the turbo?
Doodle, 2000 Black GLX, Auto.
Old 07-27-2006, 10:13 PM
bman's Avatar
Saint Catharines, Ontario, Canada
Car: 2000 GLX
I have not heard it called that, but I imagine what the Bentley repair manual calls the "continued coolant circulation pump" is the same thing.
Before I did my timing belt on my y2k GLX I pieced together a PDF containing all the tidbits I thought I'd need to know about. It contains some info on that pump, where it resides in the system, how to check its function, etc. You can find it at this link: http://www.niagara.com/~bman/2000glxcooling.pdf
I'm not sure on pricing for it, but http://parts.autopartsonlinecanada.c...ary+Water+Pump
lists it for $125 Canadian. I don't remember where it is in the engine bay but it seems to me $400+ is a bit excessive for replacing that part only. Maybe they are intent on replacing some hoses and clamps, too, but still I'd look for a better deal.
Old 07-28-2006, 12:18 AM
Default Info from the dealer
Thanks for the responses so far.
Yes, the dealer said it's the "electrical secondary water pump that is dripping coolant". It's near the bottom of the radiator slightly to the passenger side. I asked if it might be just a bad hose or connection. The advisor said no and recommended "to replace the pump and they will re-check the system".
I want to get a second opinion. Anyone can recommend a honest reliable VW mechanic in the Silicon Valley/San Jose area?
Thanks again!
My Bug is Leaking! Help! alienbogey Questions, Issues, Concerns, or Problems with the New Beetle 2 02-09-2006 02:06 AM
Coolant leaking bdlbug 2.0 Liter Gas 4 10-26-2005 12:25 AM
Coolant leaking from flange (heart valve?) rcy Questions, Issues, Concerns, or Problems with the New Beetle 5 10-15-2005 03:11 AM
Turbo leaking problem Naen 1.8 Liter Turbo 11 10-14-2005 07:38 PM
EVAP leaking?? Naen 1.8 Liter Turbo 9 10-06-2005 01:12 AM
