disconnecting battery? - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > NewBeetle.org > New Member Forum
New Member Forum This forum is the welcoming room for new members of NewBeetle.org. Please stop by and introduce yourself or ask questions on the use of the forums and this website.
Old 10-04-2008, 02:31 AM
Anchorage, AK, USA
Default disconnecting battery?
is it ok to unplug the battery?
the repair manual says no.
i dont understand why.
i got a check engine light suddenly.
on my mitsubishi i have a palm pilot i can hook up to it to tell me what the code is. its obd I, but this one is obdII and i wonder if it clears when i disconnect it and connect it back.
1999 black 2.0 beetle
Old 10-04-2008, 02:39 AM
CGK's Avatar
Beetleman
Salisbury, NC, USA
Disconnecting the battery will not harm anything. You will need to have the code for your radio though. Once disconnected it will go into "SAFE" mode and the only way you can get it work is to put the correct code in. If you don't have the code, bring your car to a dealer and they can look it up for ya.
As far as clearing the CEL, just disconnecting and reconnecting the battery will not usually clear a DTC. I would strongly recommend having your car scanned by someone with VagCom, or by an auto parts store that may be able to do it. Use a dealer as a last resort since they will charge you $$$ just to scan it.
Good Luck
Old 10-04-2008, 03:07 AM
Beetlescott's Avatar
USS ERNIE PRISE NCC 1701
LOUISVILLE, KY, USA
Thats a great idea.
Old 10-04-2008, 01:24 PM
gforce1108's Avatar
Port Jervis, NY, USA
Car: 98 Beetle TDI
I would be more interested in finding out why the check engine light is on than in finding a way to clear it.
I know there are a couple TDIers up in Alaska and we tend to have VCDS (vag-com) more often than others. There's a vag-com locator sticky over there someplace on tdiclub.com. Down here many auto parts stores will scan your car for free and tell you the codes, but some will not clear it. Do you have an autozone nearby?
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW
04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust.
57 Beetle Oval Window Sunroof
2 powerstrokes, Thing, Fox, Dune Buggy......
Old 10-04-2008, 04:46 PM
Anchorage, AK, USA
i have schucks, which is another branch of autozone. i suppose i could give them a call and find out.
and yes, last resort for stealership is always my motto.
i have been a mechanic as long as i can remebember,but when it comes to electronics, it isnt as simple as saying oh thats clearly broken.
if you guys know anyone uphere with a scanner, plaese send info.
i will check ot that tdi site.
thanks everyone
Old 10-05-2008, 11:24 PM
gforce1108's Avatar
Car: 98 Beetle TDI
Here's the trusted mech by state link:
http://forums.tdiclub.com/showthread.php?t=130044
(only one in AK - http://forums.tdiclub.com/member.php?u=31074)
Here's info from one vag-com locator site:
http://vagcomlocator.com/tinc?key=cS...ormname=VAGCOM
Here's another:
http://anglo-hexon.net:88//beowulf9/...com/vagcom.asp
And the last one:
http://www.vagtoolfinder.com/locator.aspx
They are not all up to date, but hopefully one of them is close to you. It doesn't help you too much, but before I got my VCDS I bought a cheap OBDII scanner on ebay for about $30. Pulls and clears codes and it was well worth the money.
Need help with battery wolterjwb Questions, Issues, Concerns, or Problems with the New Beetle 3 09-19-2008 01:04 PM
Battery? jkellaway 2.5 Liter Gas 12 01-06-2008 09:09 AM
Disconnecting the MAF vibelife 1.8 Liter Turbo 5 12-09-2007 09:45 PM
battery C89ZX7R 1.9 Liter TDI 14 10-21-2006 05:06 AM
Do I need a new battery? SIX SPEED Technical Modifications 11 12-06-2005 04:53 AM
