| New Member Forum This forum is the welcoming room for new members of NewBeetle.org. Please stop by and introduce yourself or ask questions on the use of the forums and this website. |
Hello,
proud owner of a 2000 VW Beetle, 2.0, 117,000 miles. I have a undiagnosed problem with my Air Conditioning Unit (AC), undiagnosed meaning that even a mechanic (non-VW) checked it out and could not find a problem: My AC works, it blows cold air. However, when I am driving and I turn the AC on, in my estimation it takes away too much of the engine's power. The engine starts shaking and when I am stopping at e.g. a red light the speedometer needle is fluctuating and the engine is not running smoothly in idle speed. After about 10 minutes the yellow check engine light appears - the last time (about 2 weeks ago) the check engine light stayed on for about 3 days and then disappeared again. In addition, after about 5 minutes, the AC unit is making a low pitch humming sound, which comes and goes. Any ideas? This is what I have have been told so far: - The clutch of the AC compressor is stuck sinc eI am not using ny AC unit enough - One of the fuses could be partially blown - My car needs a tune-up to re-adjust idle speed. That will fix the AC problem as well (what about the check engine light?) - Compressor is damaged - AC unit is low on Freon Any advice and suggestions would be greatly appreciated! |
1, scan your car with a VAGcom or VChecker code scanner and see what those CEL (check engine light) codes are. 2, Take your car to a local Vw Shop or independent mechanic to have it checked out and worked on.
| Tags |
| a/c , air conditioning , idle spped |
| Erratic Engine Idle w/ AC On | zwerglmom | 2.0 Liter Gas | 1 | 08-13-2010 12:26 PM |
| Engine idle problems | Mikey_VKG | 1.8 Liter Turbo | 5 | 04-27-2010 09:53 PM |
| Worst Case solution to rough idle problems | XCman | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 08-26-2007 01:00 PM |
| Rough Engine Idle | flybeetle | 2.5 Liter Gas | 4 | 04-12-2007 06:46 PM |
| Problem with TIP; Samco=solution? | Rynoclick | 1.8 Liter Turbo | 1 | 12-16-2005 11:13 PM |
