What should I watch for ? - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > NewBeetle.org > New Member Forum
New Member Forum This forum is the welcoming room for new members of NewBeetle.org. Please stop by and introduce yourself or ask questions on the use of the forums and this website.
Old 07-12-2011, 03:58 AM
Memphis, TN, USA
Car: 1996 Mazda 626 ES and 1967 Volkswagen standard Beetle
Default What should I watch for ?
When looking at New Beetles for sale, what are some things to look out for? I know that the timing belt and water pump need to be replaced at 60k miles, but what other things need to be checked? For example, on the old beetles, you have to watch for rust under the battery tray and running boards.
Old 07-12-2011, 05:43 PM
Memphis, TN, USA
The kind of problems I`m thinking of are electrically based. I`ve seen many complain about the engine`s computer having some type of flaw. Does anyone know what this flaw is, what its symptoms are, and how to fix it?
Old 07-14-2011, 01:04 AM
Memphis, TN, USA
I`ve also heard of some type of defective disableing device and some type of manual transmission weakness(not sure which transmission) . Does anyone know what I`m talking about? I`m going off of what I`ve read on this site and carsurvey.org.
Old 07-14-2011, 05:35 PM
Memphis, TN, USA
I just reread the thread. The questionable manual transmission is the 02M 6spd manual in the turbo S. The transmission has a weak shift fork that causes the transmission to lose 1 and 2 gear. Also I`ve been reading about some engine computer weakness. It has to do with the computer needing to be reprogramed whenever the battery is disconnected. Does anyone know why this happens?
Old 07-20-2011, 05:10 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Quit reading! Sounds like you've doomed the New Beetle right from the start. I have a 98 2.0 5 speed that has 153K and counting and have been driving it for less than 2 years and put on over 60K on it. I'd drive it back down to Florida tomorrow.
Old 07-20-2011, 10:16 PM
Oldbugman's Avatar
Jacksonville, FL, USA
Car: 2000 GLX 1.8T 5 SP
I have never had to reprogram the PCM after a battery swap, the radio yes but not the PCM. What the heck are you reading and where are you getting your info?
Do this quit reading, the internet is full of worthless info. With a bit of good scattered around.
Old 07-22-2011, 03:57 AM
Memphis, TN, USA
Ok, thank you. I just wanted to make sure that I was making a wise choice.
Old 07-22-2011, 04:35 AM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
I've owned two Turbo S's, and neither had one iota of issues with the 6-speed manuals. I personally, would not buy an automatic NB, unless it was a later year Tiptronic.
As you know, the squeeky wheel gets the grease, meaning, the problem threads take the front row. Not everyone here has a problem. Most of us are quite happy in fact.
The New Beetle is so much fun, it should be illegal!
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Where to watch UFC in the GTA? wkjeepsrt8 The Canada Corner 1 10-20-2008 08:28 PM
Watch Out For oschool FallinApartBoy Market Place Archives 6 11-14-2006 06:11 PM
