| New Member Forum This forum is the welcoming room for new members of NewBeetle.org. Please stop by and introduce yourself or ask questions on the use of the forums and this website. |
Well this is gonna be one odd first post....
5 Days ago after much jealousy over the incredible mpg you TDI owners were posting up I gave in a purchased a used 2001 beetle TDI. It was a one owner, manual transmission, 180 k, that had been maintained since new by a very reputable Denver VW shop. It drove home nicely and for 2 days was fantastic but then.....while driving home I experienced a noticeable power loss while ascending a local hill. I downshifted but did not receive the expected "pick up." As soon as I down shifted and pressed the accelerator slightly something seemed to let go.....a noticeable increase in engine noise was heard then the car stalled. In desperation to get out of the highway I attempted to start, it fired up for 10 seconds or so then died. The car would turn over after that but not start. I returned to my home grabbed my car hauler and recovered the vehicle with no additional attempts to start it. Once I returned home a visual inspection revealed no obvious leaks or catastrophic visible insult. I pulled the timing cover and it was intact and pristine. after charging the battery over night I attempted to start. Starter would not cycle the engine. I pulled the starter thinking perhaps I had fried it attempting to start it...it tested out fine. Checked the positive and negative cables, reinstalled and attempted to start with a fresh battery ...no luck. the starter seems to engage but will not turn over. Id like to turn the car over and to assess and attempt to localize the issue but just cant seem to get the thing to do it. The only code up is a 1248 which I see no correlation to this issue. Any suggestions. Thanks |
That code actually seems to be the culprit:
17656/P1248/004680 - Ross-Tech Wiki 17656/P1248/004680 - Start of Injection Timing Regulation: Control Deviation Possible Symptoms Loss of Power at high Engine Speeds Engine difficult to Start Possible Causes Start of Injection Timing Regulation not OK Injection Pump Control Range blocked/dirty (e.g. by Metal Particles) Engine has stalled / ran out of Fuel recently Wiring/Connectors from/to Injection Valve (N108) faulty Possible Solutions Check/Adjust Injection Start. See TDI Timing Checker Check Fuel Supply Check/Replace Fuse(s) Check/Repair Wiring/Connectors from/to Injection Valve (N108) Run Output Tests
Also check the clear fuel line that runs from the fuel filter to the injection pump to see if you have fuel in it. It is in the engine compartment on the left side as you are looking at the engine. You might have something as simple as a clogged fuel filter
2007 VW New Beetle 52K (hers) 2002 VW Jetta TDI 137K (mine) 1995 Volvo 850 Turbo 229K (kids) 1983 Mercedes 300D 251K (diesel commuter) 1965 Corvair Corsa 97K (fun car) |
Thanks all. I will check those items. For the life of me though I just cant figure out why it wont turn over. All of these things could prevent it from starting and effect performance but should not effect it turning over. I have multiple issues apparently.
Sorry, I thought you said it would turn over but not start....Don't worry about fuel in the system until you can get it to turn over.
I would pull the glow plugs and then try to turn it over by hand to be sure it isn't locked up for some reason.....Not to scare you but I had a friend with a "Honda" that lost oil pressure when the oil pump shaft sheared. No oil light came on for some reason, but the car stalled when the engine locked up due to insufficient oil pressure. I would make sure the engine turns free (at least 4-6 full revolutions) by hand before going much further. |
