how to remove door panels? please help - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > General Discussion > Paint and Body
Old 12-31-2008, 04:18 AM
ttttaylor's Avatar
crazytown!
College Station, TX, USA
Car: Silver 2001 VW New Beetle
Exclamation how to remove door panels? please help
i bought a used (and slightly abused ) 2001 beetle last week and want to install some new speakers, as none of them currently work.
i've figured out how to remove the rear side panels, but i'm not sure about the door panels. i want to make sure i take them off in a safe way so i don't end up breaking something! then i'd definitely have something to worry about.
any help would be appreciated!
thanks.
xo taylor
Old 12-31-2008, 04:23 PM
boblamb58's Avatar
Send Money
Levittown, PA, USA
Car: 2008 Scion xB 5-speed manual in Nautical Blue Metallic, 1999 Honda Shadow 750 ACE Deluxe
see this thread:
http://newbeetle.org/forums/showthre...d=1#post506548
scroll up for the how-to on door panel removal.
Television is more interesting than people. If it were not, we would have people standing in the corners of our rooms. If parents would spend less time worrying about what their kids watch on TV and more time worrying about what's going on in their kids' lives, this world would be a much better place.
Old 01-04-2009, 03:07 AM
concpt's Avatar
'98 red oval, '03 black v
Powder Springs, GA, USA
Car: '98 Red Hardtop with a oval rear window and beetle wheels, a '03 Black vert daily driver,
The door panels are pretty easy if you take your time. start by removong the inside door pull.(2) unscrew the star screws along the bottom of the door. (3) use a plastic pry tool to pull the panel away from the door starting at the bottom working up the sides. take care and work slow to keep from brealing the clips.( 4) emove trim around door handle. (5)be caeful pullpanel up out of window track and unhook wires to windows, locks, ect. Breif but hope it helps.
Old 01-04-2009, 05:12 AM
NaplesTurboS's Avatar
VW Turbo S
Naples, FL, USA
Car: 2002 Turbo S
dont forget the 2 philips heads under the cover in the grab or pull bar.
Jon
Old 01-04-2009, 04:37 PM
NBTurboFreak's Avatar
20V GTRS
Car: 2001 Sliver Arrow GLX
Roll the window down before you start.
1. Carefully use a thin screw driver to pry the handle cover off then remove the 2 Philips screws behind the cover.
2. Remove the 3 torx screws with a #20 driver
3. Start from the bottom of the panel and slightly pull it away from the door, there are about 4-5 grommets holding the edges of the panel to the door.
4. With the bottom pulled out lift the panel so that the top of it come off the door.
5. Undo the electrical connections at a (door marker light), b (gas and trunk switches), c (window switches), d (door lock and mirror), and e security led).
6. At d pull the black cable, at the end, till the end grommet slides out of the door handle then undo the hook from the handle.
Passenger side will be the same except there are not connections at b or e.
To put it back reverse the steps with some side notes.
A. When reversing step 4 it may be a little tricky lining up the door lock pin.
B. At step 3 (in reverse) once the top of the panel has been reseated correctly then just use your hand and hit near the side edges of the panel to seat the grommets.
This should help, if you need more clarification let me know and I can try to make some step-by-step pics.
Piczo Pics -- WoW
2012 Tiguan S 5-speed candy white (new daily)
2013 Beetle Turbo DSG (sun and sound) reef blue
Old 01-16-2010, 05:50 PM
Default removing rear side panel
"ttttaylor"
I am trying to figure out how to remove the rear side panels. You indicated that you figured that out! Please share! I'm having trouble finding this information anywhere. Thanks in advance for any help!
Old 02-03-2010, 10:30 PM
i would love some more step by step pictures.
I got the door panel detached and now i am having issues with the wires keeping the panel connected to the door. I pretty much joined this forum for more clarification on this topic. I am worried i will break something or cut something or rewire it wrong!
thanks all
-Dann
Last edited by DannWunderlich; 02-03-2010 at 10:32 PM.. Reason: making it easier to understand.
Old 02-03-2010, 10:48 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Car: Formally 2001.5 Sport 5speed-- Titan Currently 2005.5 Jetta TDI
Hey Dann! Welcome to the org!!
Dont come just for that! Come for all ther rest of the stuff here too! As usual, pics of your bug would be great too! Oh, as will before and after pics of your doorpanels
Old 02-11-2010, 06:25 AM
where do i put the pictures up? here is an external link to my FB pictures.
Dann Wunderlich's Photos - Clay: The Yellow Bug | Facebook
Old 02-11-2010, 06:55 AM
HarlequinPixie's Avatar
ElectricHarleyHouseOfLove
Currently: Williamsburg, VA, USA
Car: 2001 Batik Blue 2.0 GLS 5spd
in this section:
Photos: New Beetles - NewBeetle.org Forums
Old 02-13-2010, 04:31 AM
Default Rear panels
Does anyone have the step by step process for removing the back panels, I assume that is how you get to the rear speakers.
Old 02-13-2010, 04:59 AM
how i did it:
-with seat in regular position loosen bottom of panel from around the seatbelt bar near the doorsill (will have to pop up the back part of the sill trim piece)
-start loosening panel up the doorjamb
-lift seat bottom and begin loosening panel from bottom up.
It's just held with the round snap-in clips like the front panels but with nothing to unscrew
thankfully the rear speakers are much easier to deal with than the fronts.. they just have screws.. no weird brackets and rivets.
Old 02-15-2010, 10:44 PM
Default I will be recording my install
just incase anyone cares - I will be documenting - step by step the process for both the front and rear speaker switch.
should be fun!
-DannWunderlich
Dann Wunderlich Visuals
Tags
door panels remove
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
FS: Door Panels, Air Intake Box, Dash Grab & Door Handle Charlene_Bugy Market Place Archives 0 12-21-2007 09:19 AM
How To Remove Rear Door Panels? yellow99 Styling Modifications 5 09-12-2006 02:31 PM
FS: Black Leather F/R Seats, L+R Door Panels and Side Panels, and more!! dannyd Market Place Archives 5 09-04-2006 02:02 AM
